balast in 485
11 years 7 months ago #3688 by mrrgy
balast in 485 was created by mrrgy
IP 485 has two ballast compartments aft in lazaret port and starboard. After installing windless and ground tackle at bow I added weight to rear ballast compartments. How much weight should we expect to carry in this compartment? Why were these compartments added?
11 years 7 months ago #3689 by Augydoggy
Replied by Augydoggy on topic Re: balast in 485
I think the best way to determine how much weight to add is by looking at the waterline and seeing how the boat sits. My preference is to have her sit just a bit higher at the bow. When we bought our 420 it had a stack of lead beneath the cockpit that weighed 1100 pounds. We removed it all to install a 400 pound genset and the boat still sat pretty much the same afterwards so we didn't put any of the lead back in. Just add what's necessary for good trim.
11 years 7 months ago #3691 by jayseadee
Replied by jayseadee on topic Re: balast in 485
The ballast was intended to replicate future cargo or equipment in the aft lazarette(which can be way more than the original ballast placed). The boat should have come with the ballast in place. In my experience, once we loaded the boat up for cruising, installed an arch, and hung a dinghy on the stern: we could never get enough weight forward...I would not put the ballast back in unless you can see the bow is lower at the water line.
John--485 owner for 8 years.
11 years 7 months ago #3692 by mrrgy
Replied by mrrgy on topic Re: balast in 485
Thanks John,
Have now added much weight mid to aft of boat arch,dingy/motor, 3ac units, watermaker and scuba tanks.Also added 9kw generator. Boat came with about 60lbs iron ingots all rusty and bow was a little low. Placed in 600lbs lead. I will probably remove all 600lbs. Please let me know any additional info you would like to share about your 485. Think we have talked to you guys somewhere. We are currently in Vero Beach Florida.
Richard
11 years 7 months ago #3693 by mrrgy
Why so much weight?
Richard
Time to create page: 0.121 seconds
We have 1479 guests and no members online
