interior teak
  • gerryandnancy
  • gerryandnancy's Avatar Topic Author
15 years 6 months ago #752 by gerryandnancy
interior teak was created by gerryandnancy
Curious about the best way to maintain the interior teak in an IP27 1990. It looks good, but want to keep it that way. How about the holly/teak sole? Thanks, Nancy
15 years 6 months ago - 15 years 6 months ago #753 by hayden
Replied by hayden on topic Re: interior teak
Hi Nancy:
We have used various products and have now settled in on StarBrite Teak Oil. This is available at West Marine or Defender or Jamestown Distributors and many other places. Here are some other techniques we use to keep it clean. We will clean the surfaces with a spray bottle of white vinegar and water about 25% vinegar and 75% water. This will cut the salt and help to remove that which tends to make the teak dark. For mildew we will use a spray bottle of 25% bleach and 75% water, spray this right onto the wood and wipe off the mildew. This is also good for lockers and doors. We will usually wipe on the StarBrite oil on our way off the boat for our trip home as the odor can be strong if you remain onboard after doing a lot of teak. To make this shine and nearly look like varnish, apply this oil and while wet, sand it into the teak with 220 sandpaper or even 320 or 400 grit sandpaper. This will burnish the surface and eventually make it look nearly like varnish. Of course, if you want it to look really good, then varnish is the only way. Over time, due to the UV sun rays and these types of oils, the teak will darken with age. I am not sure how to lighten this other than lots of sanding and then a bleach. As for the cabin sole, most of these are varnished so you could brush on a new coat to renew the sole.
Enjoy the IP, these are great yachts...
Here is what we use...
Last edit: 15 years 6 months ago by hayden.
  • gerryandnancy
15 years 6 months ago #776 by gerryandnancy
Replied by gerryandnancy on topic Re: interior teak
Dear Hayden,
We are taking your advice and the vinegar followed by the Starbrite teak oil works wonderfully. We didn't need the bleach. Gerry also is using the scraper (you recommended)for the teak outside. It was mentioned on another topic. That is amazing.
Now that the teak is almost finished, please tell me what you use for the interior fiberglass. I loved Jubilee years ago but they don't make it anymore. We have 3M products and Roll Away.
Thanks for your help.
Nancy
15 years 6 months ago #777 by hayden
Hi Nancy:
We simply clean the fiberglass inside with common household cleaners like simple green or 409 etc. We do not wax the inside fiberglass.
I guess you could use the same as we use on the outside: Collinite Marine Wax.
We use the cleaner wax 920 and the fiberglass wax 925, it is fantastic!
www.collinitemarine.com/
13 years 6 months ago #1978 by Fluiddynamicist
Replied by Fluiddynamicist on topic Re: interior teak
Where can I find carbide scraper for outside teak???
V
  • gerryandnancy
13 years 6 months ago #1995 by gerryandnancy
I purchased a Bahco/Sandvik carbide scraper #650. It is a simple scraper with a double edge carbide blade. I have used it quite a bit for two years (still not done refinishing all the teak on my '91 IP27) and have not even turned the blade to the opposite side.
I am very happy with it and after a little practice works extremely well. Of course, depending on the condition of the varnish to be removed, it can peel it off very easily or sometimes more effort is required.
I believe you can purchase the scraper at some stores or many outlets online. I purchased mine online from "The College Toolbox" which at that time offered the lowest total purchase/shipping costs.
Good luck.
Gerry
Time to create page: 0.192 seconds
We have 895 guests and one member online
