Teak plugs
  • a Guest's Avatar Topic Author
17 years 1 week ago #224 by a Guest
Teak plugs was created by a Guest
I am starting to refinish the exterior teak on our IP 31. This boat has been neglected for many years. Many of the teak plugs are missing. What is the best way to install and secure the new ones?
Thank You! john
17 years 6 days ago #232 by a Guest
Replied by a Guest on topic Re:Teak plugs
John:
If the existing bung holes are in good shape then you can just glue new bungs in. Wait until the glue dries and then knock of about 2/3'ds of the exposed bung with a wood chisel. Then take some 60 grit sandpaper glued to a small strip of 1/4" ply etc. and knock the remaining bung down to just flush with the existing teak. Fininsh fairing the area with 120 grit paper the seal with the coating of your choice.
If the holes are in bad shape? Let me know....
Bobby
17 years 6 days ago #235 by a Guest
What type of Glue should one use?
17 years 6 days ago #237 by a Guest
John:
I've had very good luck with Gorilla glue or the Elmers waterproof. It doesn't take much as you just want to lock the bung in place - it will be sealed when you recoat the teak.
Bobby
17 years 6 days ago #238 by a Guest
Thank you! Does anyone use Epoxy?
16 years 11 months ago #253 by a Guest
I would not use epoxy but any of the waterproof wood glues as mentioned earlier. No need to put on a lot. I usually just brush on a light coat inside the hole and tap in the plug. The reason I would not use epoxy is that you may need to remove the plug some time in the future and you will likely damage the surrounding wood if the plug is epoxied down.
Matt
Time to create page: 0.121 seconds
We have 1198 guests and 2 members online
