Shadetree awning
  • Emergpa1
  • Emergpa1's Avatar Topic Author
  • Elite Member
  • Elite Member
13 years 5 months ago #2085 by Emergpa1
Shadetree awning was created by Emergpa1
I am looking to purchase a foredeck awning. I am considering the Shadetree awning system. I am away from the boat for a couple of weeks but would like to order it now. Has anyone used one of those on the IP 31, and if so, what size?
keith
12 years 3 months ago #3313 by Rwirtz
Replied by Rwirtz on topic Re: Shadetree awning
Keith, did the Shadetree awning work? We are looking for mid and foredeck awnings on an IP380. Thanks. Bob
  • Emergpa1
  • Elite Member
  • Elite Member
12 years 3 months ago #3314 by Emergpa1
Replied by Emergpa1 on topic Re: Shadetree awning
Rwirtz wrote: Keith, did the Shadetree awning work? We are looking for mid and foredeck awnings on an IP380. Thanks. Bob
Yes, they work very well. We bought a forward and rear awning. We have used them extensively for two seasons. Occasionally we break a pole in Highwinds but I have learn to repair them. We rarely take them down for storms anymore. Here is a real-time photo right now. As you can see we just got through with a rainstorm. I have left the polls out of the front awning. It seems to work better that way. I would recommend these
12 years 3 months ago #3315 by hayden
Replied by hayden on topic Re: Shadetree awning
Keith
We use a flat sunshade from Defender.com. it has a pole in the front and one in the back. We roll this out over the boom and then pull it tight via the shrouds. We then added simple side drops that are 8' long and one 54" bolt wide of phifertex. We use these anywhere.
We also have a sunshade bow tent that works sorta the same way.
You can see our sunshade on this blog post.islandspirit35.blogspot.com/2012/12/arrival-hcc.html
12 years 3 months ago #3316 by Rwirtz
Keith and Haden, thanks for the information on your awning systems. It's very useful as we move forward determining what will work best for us. Bob
12 years 2 months ago - 12 years 2 months ago #3364 by KurtIP31
Replied by KurtIP31 on topic Re: Shadetree awning
I own a ShadeTree and I love it, with a couple of caveats. I did by the grey and in comparative testing of mine own, it dropped inside temperature after sitting in the August sun by almost 20 degrees (about 115 inside down to low 90s) with it being in the 90s outside, that was excellent.
The pros
  • Great customer service. I think it is a couple who run the entire show and they were great in helping me figure out how I wanted it, what length and even how to shorten it myself, for a more custom fit.
  • Durable. I put it up and leave it up. The only time I took it down last year (aside from sailing) was a hurricane. Wind/Rain no problem. I think they warn you to take it down, but once you have it up you will see even heavy winds are not an issue
  • Standard sizes fit most boats. They will customize, but most of their "standard" will fit. Emergpa1 went with 2, I only needed one.
  • Useful even in the rain. Even when it rains it give you cover. So, I was out working on the deck hatches during a rain because I could. A carport of boats.
  • It covers the entire deck - lifeline to lifeline
  • It folds up small. Real small. I am not sure how they fit all of that in the small bag (also a nice feature), but it fits.
The cons
  • If you boat is almost the right size, you want to check where things fall. They were willing to take it back and cut it back a little for me, but I kept it as is. The problem is it falls onto the lifeline gate if fully extended. (Not a product issue, but a warning to watch for it)
  • It does not seem like long, but when you leave the office to go sailing, the 30 minutes it takes to take down seems long and the fiberglass poles are difficult to get in and out by yourself. Two people can get it off (stuffed into a corner) in about 10 minutes.
  • The slant of the top means you cannot walk around the deck easily with it in place. You kind of lean inward and never stand straight up. So running up to the foredeck for a second, is a little cumbersome.
I had been tinkering with the idea of what Hayden has. There are a couple of boats here that have a very similar setup. The upside, it is quick to deploy and return. It opens the side decks so walking around is not an issue. The down side is it is very low to the desk or it catches wind like the sail. So no rain cover and it does not extend (although it could) to the far sides of the deck.
If I had to do it over again would I? 93.2383% yes. But I would definitely have had them shorten it for my 31. The gate thing is continuously annoying.
Last edit: 12 years 2 months ago by KurtIP31.
Time to create page: 0.195 seconds
We have 2487 guests and no members online
