Reefing lines on an IP35
  • wanderer
  • wanderer's Avatar Topic Author
5 years 3 days ago #7124 by wanderer
Reefing lines on an IP35 was created by wanderer
I have replaced all the running rigging except the reefing lines, primarily because I have found no source what length they are.  Even the specs I got from Bill Bolin on running rigging does not include this.  They appear to be 7/16" diameter.  Does anyone have even an estimate of their lengths?  Hard to measure since so much is contained inside the boom.
thanks
Glenn
5 years 1 day ago - 5 years 1 day ago #7127 by hayden
Replied by hayden on topic Reefing lines on an IP35
Glenn:
Yes, 7/16" is right. As for length, I simplified my reefing lines down to single line reefs just like on a dinghy. To measure what you need simply start at the reefing winch measure to the mast base, then verticle up to the sail reef point, then back down to the boom, then aft to the end of the boom then up to the reef point, and finally down to the boom directly under the reef point. This is single-line reefing. I have run this way for many years and tens of thousands of miles. IT WORKS. Now, to install this you need to remove the silly boom shuttle cars that IP put into the boom. Drill out the boom rivets on the aft end and pull the cars , ie, two blocks wired together, and toos them overboard :-). Now rig as a single line reef system. Yes, then do this same system for reef #2. You will be amazed at how easily it works.
One last detail, the front of the boom, you will need a bolt thru the fitting to hold the front boom sheaves in place because your pull is reversed. Still, it is all worth it.
Look under the RIGGING section in this forum and you will find more discussions on this SINGLE LINE REEFING. Here is one.
www.ipyoa.com/forum?view=topic&catid=46&id=2363
Last edit: 5 years 1 day ago by hayden.
The following user(s) said Thank You: wanderer
5 years 1 day ago #7128 by hayden
Here is my blog post with many photos of how I changed to this SINGLE LINE REEFING system. Again, this works well.
svislandspirit.com/ip35-boom-refit-to-single-line-reefing/
Time to create page: 0.115 seconds
We have 766 guests and no members online
