Mast Boot Deck Pin Mast Collar
12 years 5 months ago - 12 years 5 months ago #2873 by hayden
Mast Boot Deck Pin Mast Collar was created by hayden
Here are some photos of the right way and the wrong way to install a mast boot and seal around the deck collar on an Island Packet 35. The mast wedge is an L shape piece of rubber where the long part of the L presses into the gap between the deck collar and the mast. The mast pin is a SS pin that goes through the deck collar and through the mast. Both of these items need to be clamped. Clamping the mast wedge presses it against the mast and helps to seal out water. Clamping the mast pin prevents it from moving side to side and coming out of the mast deck collar holes. Once the mast wedge is clamped, add silicone sealant around the joint to help with the seal. After all the the clamps are on and secured, next wrap the mast collar and joint with boot tape which works like rigging tape but is 4" wide. It will stretch twice its length and it will stick and seal back onto the previous layer. Go around and around the mast making a good seal. Finally use silicone caulk and caulk the slots and gaps due to the shape of the mast cross section. At this point your mast joint at the deck is perfect and is sealed and will not leak.
Here are some photos of this process.
This is what it SHOULD NOT look like. This is an upside down mast boot! It leaked a lot
This is a proper job with no leaks!
This is the mast wedge with NO CLAMPS, also the mast pin is NOT clamped
Clamps added and sealant added
Notice the lower clamp around the mast pin, this is important!
The finished job, and zero leaks
Last edit: 12 years 5 months ago by hayden.
12 years 5 months ago - 12 years 5 months ago #2875 by Ed Finn
Replied by Ed Finn on topic Re: Mast Boot Deck Pin Mast Collar
cool !
I never thought of putting the hose clamp around the mast collar / wedge itself
yes the method shown looks very tight.
Is that the SS mast pin there in the middle of the 3ed photo ?? Gee, I don't think I have one of those ...
Good Job Hayden
Ed
Last edit: 12 years 5 months ago by Ed Finn. Reason: asked a question
9 years 6 months ago #5527 by shawnee
Replied by shawnee on topic Re: Mast Boot Deck Pin Mast Collar
Hi Hayden,
Nice pix and explanations. We have had a small mast leak on Shawnee for some time now - maybe a year. Finally got around to fixing it, by cleaning and redoing the mast collar seal, and boot, and relocating clamps - to clamp mast collar around mast and 2nd clamp around deck plate lip. (ours has lip going up, and lip down overlapping deck plater, as well as inner lip between mast and deck plate). This helped a little. Then I did search of old IPMail, and search IPYOA. Good info. Turned out I had a leak at mast deck plate I never noticed. I'm just using seal around edge for now. Lifting and resealing, is project for another day when mast is out, and I can get deck plate anodized (rather than painted).
Hope you are enjoying your trip south and east. Great reading your blogs.
Drew
9 years 6 months ago #5529 by hayden
Replied by hayden on topic Re: Mast Boot Deck Pin Mast Collar
Thank you Drew. I am glad you found your mast leak and that you were able to redo this. I too just keep a caulking bead around the mast deck plate at the deck. This helps to keep that sealed as well. This has not leaked since doing as shown above now nearly 3 years ago.
Thanks for following our blog at www.IslandSpirit.us we are really enjoying Puerto Rico, what a surprise this island has been. Sat we power on east into the lighter trades but still into the trades. Thanks for sailing along.
Hayden in Salinas, Puerto Rico
9 years 5 months ago #5585 by Sailing Horn
Replied by Sailing Horn on topic Re: Mast Boot Deck Pin Mast Collar
Hayden - What sealant did you use around the mast?
9 years 5 months ago - 8 years 11 months ago #5586 by hayden
Steve
I used Boat life caulk and it's working great this year in the Caribbean, no mast leaks. None.
Last edit: 8 years 11 months ago by hayden.
8 years 11 months ago #5848 by aguy
Replied by aguy on topic Re: Mast Boot Deck Pin Mast Collar
Hi Hayden
I have a rainwater leak getting in under the mast deck plate on my IP-35 (#84). Going to lift the plate and re-seal underneath. Have you done this - what was it sealed down with and any tips?
I don't have a pin through the mast - there is a hole each side of the deck plate but no hole through the mast, just held in position with the black rubber gaiter.
Andrew - IP35-84, UK
8 years 11 months ago #5849 by hayden
Andrew:
The caulk I use is BOAT LIFE caulk. This works well and you can see above how I caulk and wrap the boot tape around to finsh it all off. This all works very well. I would also ue the same caulk around the base of the deck plate. I would caulk it and not take it off, unless you really think it is required.
The mast deck plate pin is rather important. The purpose of this pin is to add stiffness to the deck when the rig is under load and sailing offshore. Without this deck mast pin, the deck can flex up due to the forces of the standing rigging pulling on the deck our near the edge. These pulling up and in and this tends to flex the deck upward at the mast plate. So the pin thru the deck plate and thru the mast stops this. You can carefully drill the hole into the mast then push the pin thru. I secure mine in pace with a large hose clamp making sure it does not move side to side. See the photos above.
Best wishes for working on your mast.
Time to create page: 0.592 seconds
We have 815 guests and no members online
