Aluminum water tank
15 years 1 month ago #763 by Skye
Aluminum water tank was created by Skye
We are the new owers of an IP35. With an aluminum water tank, we understand that clorine will corrode the tank. How do you prevent this? On our old boat, we used a charcoal filter to remove minerals from well water, but because our tank was fiberglass we added a tiny amount of Clorox when we fill the tanks. What should we do to maintain and protect the tank? SKYE
15 years 1 month ago - 15 years 1 month ago #768 by hayden
Replied by hayden on topic Re: Aluminum water tank
Skye:
IP35....now thats one of the best IPs made! :)
We own IP35-165 since 2001...love it
YES...filter out the chlorine before filling your water tank every time. Simply use a Camco Water Filter on your fill hose as you fill the tank. Chlorine in your aluminum tank will make aluminum chloride and these little white chrystals will clog your pumps and screens.
I have not had these crystals since using this filter. The filters cost about
$17.00, I use one per year from Walmart, see the camping section.
www.walmart.com/ip/Camco-Water-Filter-with-Hose/14504321
See picture of what you need:
Also review this thread...
ipyoa.com/forum/44-plumbing/457-cleanout...fresh-water-tank#462
Last edit: 15 years 1 month ago by hayden.
15 years 3 weeks ago #781 by Holiday
Replied by Holiday on topic Re: Aluminum water tank
Skye,
Congrats on the good decision to get an IP. You will find a wealth of information on this topic. It is possible if you tie into the pickup of the tank going to the water pump, you can run chlorine through the hose lines to clean them out to eliminate bacteria and odor. Simple process once you are set up to do it.
Good luck with the boat and keep monitoring the IP message sites (IPYOA and IPmail) and you will have more projects you know what to do with. Or, learn more in a short period of time than you could in years of ownership. This is a wonderful group of caring sailors.
Pat
IP 38
Holiday
Jamestown, RI
Holiday
IP38 #69
Jamestown, RI
Time to create page: 0.162 seconds
We have 1430 guests and no members online
