IP 350 Replacement Holding Tank
  • Ugodive
  • Ugodive's Avatar Topic Author
4 years 6 months ago #7209 by Ugodive
IP 350 Replacement Holding Tank was created by Ugodive
Hi,
I just thought I'd share my experience replacing the holding tank on our IP350. We chose not to cut out the sole to install a tank where the old one was. I left the old, leaking, aluminum tank in place and filled it with expanding foam. I had a new tank fabricated to fit directly behind the toilet, against the hull. The new tank is much smaller (about 14 gallons), but has the huge advantage of being serviceable, visible, and, very importantly gravity feed. That's right, no more pumping to empty it.
All waste goes into the tank from the head (no Y-valve). You open a single valve at the bottom of the tank and the overboard discharge thru-hull and the waste flows easily out the bottom of the tank. There is a Y-valve between the tank and the overboard to select to pump out through the deck. This is how many French boats are built.
You could likely increase the capacity to 20 gallons, as I didn't use all the available space. I made a video of our experience that you can watch at:
photos.app.goo.gl/LF9GJ8vC8cDPCDVFA
The following user(s) said Thank You: paulb
4 years 6 months ago #7210 by hayden
Replied by hayden on topic IP 350 Replacement Holding Tank
Fantastic idea and design. That makes a lot of sense to me. Perfect solution!!!!
Outstanding!!!
Time to create page: 0.081 seconds
We have 1143 guests and no members online
