Water tank inspection port
  • SLaz
  • SLaz's Avatar Topic Author
9 years 3 weeks ago - 9 years 3 weeks ago #5666 by SLaz
Water tank inspection port was created by SLaz
Hello All,
I see the topic of a water tank inspection port has come-up on this form before, but I'd like to raise it again.
I was using my galley pump during commissioning, and some vegetive matter flushed out. Not terrible, but not great either. But it seemed like a good idea to clean out the tank. Examining it, I admired its generous inspection plate, and thought it might be a pretty simple task. At first! The problem is that it's long axis runs abeam the ship while the floor boards run fore-and-aft. The net result is that 3 of the 10 screws holding the plate in place are covered by the sole and unreachable with only 1 1/2 inches clearance. You'd have to drill a hole in the teak to get to them, which I am not about to do.
The tank appears to the the original aluminum tank. Has anyone managed this problem or have any ideas as to how to approach it?
Steve
Getting There
IP 370
Last edit: 9 years 3 weeks ago by SLaz. Reason: Typo
9 years 3 weeks ago #5667 by twofortheroads
Replied by twofortheroads on topic Water tank inspection port
Steve,
The water tank on the 370, at least ours, is not aluminum. Per the factory specs it is " ThermoCure molded , baffled fiberglass made with FDA approved VE resins...". Have not had your problem, nor attempted to remove the top metal piece but will look next time on boat.
Harry Burns
IP 370-24
Time to create page: 0.110 seconds
We have 933 guests and one member online
