Getting help from the IP factory has been key to solving problems with legacy equipment aboard our 1995 IP37 Windragon. We are the third owners, the previous owner John and Kathy Lesniak were based in St Petersburg for 15-years and had great reports of working with Karsten over the years.
Our water sending unit is the original install. The part is made by Rochester Guages. Getting a replacement turned out to require some detective work. Rochester doesn't make direct replacement. Instead they make a generic sender that needs to be custom fit to the tank. Furthermore, they only wholesale senders ...... So
Single senders can be purchased from e-components of Lancaster Virginia.
www.ecomponents.net. 804-462-5679. Ask for Tammy.
To our understanding senders for the diesel tank and for the holding tank, if installed, can also be retrofitted to legacy equipment.
