Flushing w/Sea Water vs. Fresh Water?
16 years 1 month ago #333 by hayden
I understand that many IO owners flush their heads with fresh water, while I have been using sea water for 20 years. Now as I replace my sewer lines a second time due to the saltwater and urine calcium that builds up, I am wondering about fresh water flushes.
What's your opinion Fresh water vs. salt water? If you use fresh, how do you use it? If you use salt water what do you do to prevent build up? Any feedback is appreciated.
16 years 1 month ago - 16 years 1 month ago #334 by a Guest
Replied by a Guest on topic Re:Flushing w/Sea Water vs. Fresh Water?
Hayden:
My opinion is that the problem is aggravated when "not enough" water is used to flush resulting in the build up of the uric salts in the plumbing system. We flush with salt water using an electric toilet with a preset flush rate. Eight seconds for liquids and sixteen for solids. I personally use a pee bucket overboard whenever possible.
Bobby
Last edit: 16 years 1 month ago by a Guest. Reason: correct a word
16 years 1 month ago #335 by margo
Replied by margo on topic Re:Flushing w/Sea Water vs. Fresh Water?
Hi Hayden,
We have always used fresh water to flush... due to issues with growth, tank treatment etc... given the large fresh water tank in he IP and the accessibility to fill it as needed... I instruct crew to fill the bowl with the shower head, dry flush then fill the bowl again 1/2 and dry flush... obviously pump out's need to be done. I can usually get by with 2 weeks or so... depending on use.. obviously
This may change due to accessibility of fresh water
The photos you posted late last year... confirmed for me that the fresh water use is the best way to go for me..
Margo
Margaret Dolan
s/v Windseeker IP 38-168
Port Kinsale, VA
16 years 1 month ago #338 by a Guest
Margo:
Given the small amount of water that you are using to flush the head there is probably waste being left in the lines after each flush. Give it a season or two and your waste lines will be fouled and will have to be replaced.
Bobby
16 years 1 month ago #367 by Galileo
Replied by Galileo on topic Re:Flushing w/Sea Water vs. Fresh Water?
Hello,
A friend of ours who worked on a sea-going tug, who also did the welding on the stainless bracket that holds one of the pump-out valves on Galileo (see IPPhotos for that post) mentioned to me that on the sea-going tug, on the third shift a responsibility of one of the crew was to flush the entire head plumbing system with fresh water. Sea water and urine seem to combine and form calcium which subsequently builds up and clogs the lines as you experienced.
It wasn't the most pleasant project we have undertaken, but if you got to do it looks like you did a nice job. It would be nice to have some sort of window to be able to monitor the plaque build-up.
Gerry & Larry Rossi
  • Unruly Seahorse IP38-181
  • Unruly Seahorse IP38-181's Avatar
16 years 1 week ago #388 by Unruly Seahorse IP38-181
Replied by Unruly Seahorse IP38-181 on topic Re:Flushing w/Sea Water vs. Fresh Water?
Being in the Navy for 35 years, I knew there was a product used on ships to clean out the lines and keep them clean. Imagine trying to replace clogged lines on an aircraft carrier when they are a hundred or more feet long and made of steel pipe. Anyway, here's a link to such a product. Maybe one of these tablets every so often would do the trick for those flushing with salt water.
www.sciencofast.com/products/tablets/sp-cpt.html
Personally, I flush with fresh water. I installed a three way valve that lets me choose fresh or salt, but I always use fresh while I'm just monkeying around the Chesapeake bay.
Jerry Budnick
Unruly Seahorse, IP-38-181
Solomons MD
16 years 1 week ago #389 by Unruly Seahorse IP38-181
Jerry Budnick
Solomons MD
16 years 1 week ago #390 by hayden
Replied by hayden on topic Re:Flushing w/Sea Water vs. Fresh Water?
Jerry:
WOW, this looks like something I need to check into. I read the page link and information and it seems like a very good product and the solution to prevent the build up. I would like to talk to them and see if they can be used with our small PHII plumbing systems. Thank you for the reference and for the link. I have also added it to the links database as well.
Also, I may add a system like you did to use freshwater as well. This is a good idea when local and not cruising.
15 years 4 months ago #600 by alnmar
Replied by alnmar on topic Re:Flushing w/Sea Water vs. Fresh Water?
Hello
I've been using fresh water from the shower head to flush for 1.5 years, seems to work fine but a bit cumbersome and hard to explain to new crew and visitors.
So as and alternative I've spent time drawing up diagrams of 3 way and check valves for our Packet Cat's hand pumped fresh water supply system to plumbed directly into the dry/flush valve on the PHII toilets.The benefit: No more complex instructions and dripping shower head. Liquid on both sides of the hand pump piston, no more "two handed operations. It sounds slick and will work, however.
I've not cut into the system. It's not the plumbing I'm concerned with, I'm just not sure I can eliminate the risk of cross contamination from the chance of "back-flow" of waste water into the potable system.
Land based code call for air gap and back-flow prevention between the two water systems. I don't want to create a problem so I'm looking for ideas
Any thoughts on this?
15 years 4 months ago #601 by a Guest
Just use salt water - way easier, especially if you are cruising.
Bobby
St Lucia
15 years 4 months ago #616 by alnmar
Hello Bob,
Yes I agree, but 3 grand kids and other shore side commitments are keeping us tied to the dock for now. The exception being weekends and short vacations. The system lays unused and hence the raw water lines stay filled with sea water and the first few flushes are "breath taking" to say the least.
Thanks and enjoy St. Lucia. Any volcanic activity?
15 years 4 months ago #617 by a Guest
If dock based the FW is probably a good answer. I would not want to connect the head directly to the FW tank though. Any way you can install a second tank just for the flush water so you don't risk contamination?
When we were dock based we put a quick connect fitting at the raw water input, connected fresh water to it and then ran fresh water through the hoses to keep the first few flush smell to a minimum on our return to the boat.
No volcanic activity here - expect we will get the usual view as we continue North from Montserrat.
Bobby
15 years 4 months ago #619 by paulsailorirish
Replied by paulsailorirish on topic Re:Flushing w/Sea Water vs. Fresh Water?
we have used vacuflush fresh water system without any problems or odors
15 years 4 months ago #620 by a Guest
Paul:
The Vacuflush is a whole different system and the interface with the fresh water is different as well - what boat is the system installed in and did you add it or was it factory installed?
Bobby
15 years 3 months ago #676 by paulsailorirish
Added to ip 35 by previous owner . Had to do a significant amount of work to straigthen hoses and avoid 90 degree turns . After work no more blockage or air leaks( critical to maintain vacuum ) . Works well with no odors and minimum use of fresh water
Paul
S/v tenacious ip 35 146
Time to create page: 0.146 seconds
We have 1052 guests and no members online
