Waste system tank venting problem on IP 40
  • mfrobb
  • mfrobb's Avatar Topic Author
14 years 4 days ago #1429 by mfrobb
I was wondering if anyone had a solution to a venting problem. I have an IP 40 with two heads. Using both heads within minutes of each other results in a buildup of pressure in the tank necessitating releasing the pressure within the storage tank by opening one of the overboard discharge valves (otherwise the handles on the head remain in the upright position and will no longer allow flushing). I have ensured that both the hose as well as the "very small connection" into the tank itself is clear. My impression is that the opening into the tank was not designed with much error margin for clogging. Has anyone else had this experience?
14 years 4 days ago #1430 by hayden
Mark
This is for sure a vent line blockage. First i would look at the vent line where it exits the hull and make sure the it is not blocked. These can get packed with mud from wasps etc. pop the creen out if the vent if it still has on, then poke a wire into the vent to clear it from the outside, note that the vent fitting is a 90 degree smooth bend into the hull. On the inside it will then have a rubber host to the holding tank. Get this vent unplugged.
Next solution is to go to a pumpout station and put the pump onto the pumpout fitting. Then when evacuating the tank, you should hear lots of air also being sucked into this vent fitting. At this point take a water hose and spray water at this fitting allowing it to suck water into the vent flushing it as well.
At this point your vent line system will be clear and the problem will be solved.
Let us know how it goes and if this fixes the problem.
The following user(s) said Thank You: CapnBlaine
  • mfrobb
14 years 1 day ago #1437 by mfrobb
Thanks Hayden — I will give that a try.
Time to create page: 0.090 seconds
We have 1060 guests and no members online
