Replacing bilge pump and switch on an IP 350
  • jmurth
  • jmurth's Avatar Topic Author
14 years 2 weeks ago #1397 by jmurth
I believe I may have to replace the bilge pump and switch in an IP 350. I thought Hayden had posted info with pics on a replacement he performed on an IP 35. Anyone have any info on this?
14 years 2 weeks ago #1398 by hayden
Jim:
Yes, I replaced the bilge pump and switch on our IP35, the photos essay is here:
ipyoa.com/photos/62-hayden/album?albumid=93
The following user(s) said Thank You: jmurth
  • jmurth
14 years 2 days ago #1433 by jmurth
Thanks to Hayden for pics of his replacemnt.....We purchased the IP350 on 5-22-2012. It has the Rule 3700 with 1 1/2" outlet. Ordered new pump and Smart Switch from Defender & will install this week.
Looks like it will be a fairly straight-forwarded switch if we remove the short engine supply hose so we can raise the pump/switch mount to a workable level.
  • jmurth
13 years 11 months ago #1442 by jmurth
I was looking at the IP wiring diagrams for the bilge pump and float switch.
It appears to show two DC + (one for when the IP switch is in auto mode and one for the manual override) connecting to the float switch. Wondering if the original switch had a manual overide function that powered the pump when holding the momentary toggle in manual position.
The smart switch ss-209-12 appears to have a single DC + connection that will power the pump when the float rises and completes the circuit. Seems like I would connect the IP + wire from the automatic side to the smart input and just have the DC+ from the IP manual side connect to the smart output to the pump + (Then the pump would have two DC+ inputs: one operated by the smart switch float and one by the manual IP momentary toggle.) Is that how you connected your new switch and pump?
thanks..........jim murtha
13 years 11 months ago #1443 by hayden
Jim:
Yes, that is how I have ours set up. I can use the manual on switch and the float switch is auto. You have it exactly right.
Time to create page: 0.088 seconds
We have 1055 guests and no members online
