IP32 Quarterberth Mattress
  • smconrad
  • smconrad's Avatar Topic Author
9 years 7 months ago #5427 by smconrad
IP32 Quarterberth Mattress was created by smconrad
I need to replace our worn out quarterberth mattress. The existing mattress is two sections connected lengthwise by a sewn in hinge that allows one half of the mattress to be folded over the other for access to the compartments below it. There is a cutout and separate cushion over the engine compartment itself, but it's a real pain folding the mattress over every time I need to access the raw water strainer, shaft log, etc.
I'm thinking about replacing the folding half (the inboard half) with three separate cushions instead. I can't see why this wouldn't work.
Has anyone tried this?
9 years 7 months ago #5429 by Angelfish
Replied by Angelfish on topic IP32 Quarterberth Mattress
Yes, we did this on our IP32. It works very well and gives us easy access.
  • smconrad
9 years 7 months ago #5430 by smconrad
Replied by smconrad on topic IP32 Quarterberth Mattress
Thanks for the reply!
Did you have to do anything to keep the outboard section (the large half) from sliding away from the cushions? I wonder if the aft end would need to be held down with Velcro to keep the two halves from separating.
9 years 7 months ago #5438 by Angelfish
So far there hasn't been a problem. Rather than wrestling around trying to cover the entire aft section with a bed pad and sheets, I purchased 2 twin sized memory foam pads from Costco (3 inches thick), and make up the two "pallets" with twin sized sheets. This sure has made getting into lockers and checking the bilge a lot easier.
Time to create page: 0.109 seconds
We have 632 guests and no members online
