stainless steel port lights
  • Bratsdad
  • Bratsdad's Avatar Topic Author
9 years 9 months ago #5393 by Bratsdad
stainless steel port lights was created by Bratsdad
Looking to replace a stainless steel port light on a 1990 Island Packet 32. Can anyone tell me who the manufacturer is? There are no markings on port light. The thumb screws are the ones with the triangle shaped knob.
9 years 9 months ago #5394 by shawnee
Replied by shawnee on topic stainless steel port lights
Hi Bratsdad - Not sure about the IP32, but later IP's including IP380 had port lights very similar to (or exactly the same as) rectangular lights from Marine Depot Direct. The link below is for IP380 ports. If not these, check out the other sizes.
www.marinedepotdirect.com/stainless-rect...-portlight-1423.html. Usual disclaimers - no interest in these folks. (but I had good experience buying from them)
  • Bratsdad
9 years 9 months ago #5395 by Bratsdad
Replied by Bratsdad on topic stainless steel port lights
Thanks for the response. These look like the same ports. There are a couple things different but I dont think it will matter. I really only need the inside frame with the glass. Somebody went on one of our brokerage boats and "borrowed" one of the lenses and inside frame. They forgot to bring it back. (lol) The knobs are different and these have a support arm which the old ones did not. The knobs are not a big deal since the old ones are still on the existing port. I will call the company and see if they can tell me if this is a replacement. Thanks again
9 years 9 months ago #5398 by shawnee
Hi Ed - - as fyi - our ports are the 14-3/4" x 4-3/4" (fairly sure on that). Would be good to double check the size of your ports and the distance between hinges to make sure things match. Also, they have models without the lift arm (likely standard model) and for the complete assembly - various options on the spigots. I think ours are straight spigots (but good to check if you are buying a complete port light. Good luck.
Time to create page: 0.226 seconds
We have 2864 guests and no members online
