- Thank you received: 3
That's a good idea of putting the insulation inside, as we never even fill up our smaller IP 31 icebox. However, we do have a bit of problem with drainage and wondering how well your unit drains and how the moisture would collect underneath and in the small cracks that you would inevitably have with the reflective insulation there. Periodically we have to clear the drain with a small piece of seizing wire.hayden wrote: One of the weakest aspects of the Island Packet, the older models, would be the insulation behind the ice box. It is sprayed in and it is well known that there are voids. So, it is best to do what you are doing, that being adding foam board insulation to the inside. We kept it simple and used 2" on the sides and 4" on the bottom. Then we covered this with, the simple to use, RFLECTIX air conditioning foil faced bubble wrap. The seams were taped together with aluminum tape. This has works for many years. We think easy is better than vacuum panels, fiblerglass custom lids, special lid gaskets and all this. Just keep it simple, insulate it with boards, and cover it with reflectix, and you are done.
Here is a detailed photo album:
ipyoa.com/photos/62-hayden/album?albumid=92
Installing the refrigeration unit is very straightforward. First of all the refrigeration unit, as you can see, goes the built in base on the port side of the boat just to the rear of the galley bulkhead. Hopefully you can see that the tubing goes through the bulkhead into the cooler at the rear slightly to Starbord side of the cooler. The freezer box is mounted on the starboard side of the cooler. That is better than the back because it would be more difficult to get to back there. The installation is really very straightforward as all you are doing is wiring in the unit and drilling a hole through the cooler. Then you feel that whole with the spray insulation you can get at Home Depot.cat30 wrote: Keith- what wall of the ice box did you mount the evaporator? and any more info about your installation- i'm trying to figure out how to install the tubing without too many bends- or running into any of the blown-in foam already surrounding the icebox. I'm thinking of the starboard wall or the back wall for mounting.
i've already installed 2-inches of foam all around but i plan to put something over it and seal all the edges.
We have 2973 guests and no members online
Island Packet and Island Packet Yachts are registered trademarks of IPY (Island Packet Yachts, Inc.). IPYOA and The Island Packet Yacht Owners Association, have no affiliation with IPY, the Island Packet Yacht Company. Throughout our IPYOA Facebook Group and on this IPYOA.com website the terms Island Packet and Island Packet Yachts are used for identification purposes only. This use is FAIR USE and NOMINATIVE. We are NOT a yacht manufacturer we are a yacht owners group.
