Propeller shaft vibrations on ip35
  • galfé
  • galfé's Avatar Topic Author
7 years 1 week ago #6673 by galfé
Propeller shaft vibrations on ip35 was created by galfé
Hi there, as I am thinking of buying a used IP 35 from 1990/1991, I had some talking with IP35 -owners and they were complaining about often damages on cutlass bearing, gearbox, clutch and engine brackets caused by vibrations of the propeller shaft. This shaft is rather long and one of the owners had installed an interim bearing on the half length of the shaft to stop the swinging. Has anybody experience with this problem and its solution?
Is that also a problem on the smaller IP 32 with the shorter propeller shaft?
Fair winds, George
7 years 6 days ago #6674 by hayden
Replied by hayden on topic Propeller shaft vibrations on ip35
George:
No IP needs a strut or bearing on the shaft. I have sailed and motored out IP 35 since 2001 and we have 35,000 nm under her. This vibration is always caused by a bad out of balance prop. Many IP 35s and IPs in the 1990s opted for the "factory upgraded" feathering $3,000 option prop by the knock off company called PROWELL. These props over time will develop a different pitch on each blade becuase the blades stop up against a bronze stop. This stop mushrooms over and then the blades are at a different pitch. Today, these props can be serviced by Veri-Prop USA. Personally I would toss out a prowell prop, we did and we were so happy to toss it overboard.
If the vibration is not from one of these upgraded PROWELL feathering props then it could be from an unbalance fixed three balded prop.
If not the prop then it is the motor mounts and a mis-aligned engine.
Do not re-engineer the IP35, it is just fine the way it is designed, like most IPs. Prop shaft vibration is always from one of these issues:
Prop Blade pitch difference
Motor mounts
out of aligned engine
www.svIslandSpirit.com 12 years of IP35 blogging stories
6 years 5 months ago #6766 by ktmissouri
Replied by ktmissouri on topic Propeller shaft vibrations on ip35
I was searching the forum today to see if I could find information on the correct propeller for our 1993 IP 35 and found this old thread. I see you replaced yours. I am trying to determine if our current prop is the right size and pitch. I don't know if ours has been replaced, but it is certainly possible. I am getting black soot on my transom when motoring hard and I suspect it may be incorrect size on the prop. Any information you can provide would be helpful. Thanks, Shawn
6 years 4 months ago #6767 by hayden
Shawn:
We have the original 3 bladed fixed prop which is a 14" pitch x 17" diameter, if I recall. We have the 38 hp Yanmar 3JHH2e, we run at 2600 rpms. Wer too will get the typical oil on the stern. This is due to the stern digging in and lowering when runnig PLUS the fact that the exhaust is deposited into the back wash of the water coming off the stern. To reduce this, some have added a 24" piece of fire hose clamped to the exhaust to deposit the exhaust into the water that is flowing aft and not circling back into the hull.
Every old 2 digit IP has this oil on the stern due to a poorly designed underbody stern shape and the poor trailing stern wave. If the stern were lifted like on the 3 digit boats with a diving platform,..,.,ugh ...I mean a swim platform/sugatr scoop then this lifted stern is OUT of the stern wave and the water trails off the back properly.
So, do not think it is all engine or prop. It is hull design as well.
The other thing you can do is to move weight forward. On the IP35, we have every spar part, every heavy item in the most forward vee berth locker under the bed. This helps to drive the bow down and lift the stern.
I hope this helps. Sorry for the delay, we are moving around the USVI
6 years 4 months ago #6768 by ktmissouri
Thanks for the reply.
Shawn
Time to create page: 0.113 seconds
We have 925 guests and no members online
