Transmission Oil Leak Repair
  • spinache
  • spinache's Avatar Topic Author
11 years 7 months ago - 11 years 7 months ago #3859 by spinache
Transmission Oil Leak Repair was created by spinache
Here is my description of a DYI repair of a transmission oil leak that turned out to be the O ring instead of the oil seal. My boat is a 1989 IP35 hull #016. The seal, O ring and locking nut had been replaced 7 years earlier by a Yanmar mechanic for $1300. I did this without removing the transmission and I did it myself for the cost of parts ($33.43) in about 8 hours. Attached is a PDF file showing how I did this.
File Attachment:
File Name: KBW10Trans...rPDF.pdf
File Size:2,291 KB
Last edit: 11 years 7 months ago by spinache.
The following user(s) said Thank You: Emergpa1, Nsail
6 years 5 months ago #6759 by Nsail
Replied by Nsail on topic Transmission Oil Leak Repair
This is of immense help to me. I'm new to sailing & recently got a salvage IP35 that has the same leaks & need to fix.
By any chance is there dimensions info on the tool so i can make one?
Much appreciated.
Thank You
  • spinache
6 years 5 months ago - 6 years 1 month ago #6760 by spinache
Replied by spinache on topic Transmission Oil Leak Repair
The tool my brother-in-law made out of an aluminum bar and some nuts & bolts is on the boat. I’m going there tomorrow and with take measurements for you.
Last edit: 6 years 1 month ago by spinache.
  • spinache
6 years 5 months ago - 6 years 1 month ago #6761 by spinache
BTW, it’s been 5 years and, knock on wood, no leaks!
6 years 2 months ago #6800 by Bagheera MTL
Replied by Bagheera MTL on topic Transmission Oil Leak Repair
HI Jim,
Fantastic guide! I would also be interested in the measurements for the tool if you have them?
Cheers,
Tom
6 years 1 month ago - 6 years 1 month ago #6805 by hayden
Replied by hayden on topic Transmission Oil Leak Repair
Here is a photo essay on the KBW10 Output Coupler that can come loose and cause these transmission leaks. Jim did a great job showing the entire process of the repair. See photos of the tool I made to fix this one time while cruising up in Maine.
These were published:
Friday - August 27, 2010
Transmission Output Coupler
www.ipyoa.com/photos?view=album&aid=552
Last edit: 6 years 1 month ago by hayden.
  • spinache
6 years 1 month ago - 6 years 1 month ago #6806 by spinache
10” long
1” wide
1/4” thick
1.5” between center of 2 mounted 1 1/2” x 1/4” bolts that extend 3/4” from bolt surface
The following user(s) said Thank You: Bagheera MTL
6 years 1 month ago #6812 by Bagheera MTL
Thank you very helpful! By the way That nut is rather pricey and it appears that there’s no issue to reuse it in case it helps someone.
Cheers!
5 years 10 months ago #6881 by Bagheera MTL
Update from about 1500 miles down the road, make sure you use locktight and that you have enough metal left on the nut to caulk it. I did not and it came off in a rather extravagant way. As I went to replace it I noticed some serious wear on the output coupling (will have to be replaced unfortunately) and some wear on the output shaft. Changing that shaft requires a rebuild that I’m not convinced the transmission needs and/ costs a fair bit of money. I noticed that your shaft has a similar amount of wear Jim, maybe slightly less than mine, but it appears that you have gotten about 5years out of it so far. Any idea how many hours you’ve put on the engine since? Trying to decide if I should go down the full rebuild route or just replace the coupling/ nut / rear seals?
Time to create page: 0.369 seconds
We have 1091 guests and no members online
