compression check
  • Tikkun
  • Tikkun's Avatar Topic Author
12 years 2 months ago #3335 by Tikkun
compression check was created by Tikkun
Does anyone know if a compression check can be done on a Yanmar 30gm without hauling the engine? I have a IP 31.
12 years 2 months ago #3336 by hayden
Replied by hayden on topic Re: compression check
The fuel injectors are removed and a pressure gauge is treaded into the one cylinder. Then the engine is cranked over with the fuel stop pulled out so it want start. The PSI is read and this is the compression reading for that one cylinder..this is repeated for each cylinder.
Yes this can be done with the engine in the boat.
Time to create page: 0.112 seconds
We have 2708 guests and no members online
