shaft alignment technique
  • Captdds
  • Captdds's Avatar Topic Author
12 years 4 months ago - 12 years 4 months ago #2888 by Captdds
shaft alignment technique was created by Captdds
I have 420 that slings a little water when in gear. It does not drip when not turning. A new cutlass bearing was installed 3 years ago. I do not think the engine was aligned at that time. What is the best way to do the alignment? I have done shorter shaft lengths with no problem. The 420 shaft is pretty long from the cutlas to the connection plate with no support. Is the shaft weight a problem? Should I repack the cutlass with new packing before aligning or is it better to align to the current shaft position? Thanks for any response! Captdds
Last edit: 12 years 4 months ago by Captdds. Reason: Stuffing box also replaced
12 years 4 months ago #2894 by hayden
Replied by hayden on topic Re: shaft alignment technique
Guy:
The best way to align the engine is to loosen the shaft coupling, the four bolts that connect the shaft to the transmission. Then using a feeler gauge "feel" the space around the flange. This will tell you if the flange is tight on one side. Now look at your motor mounts and raise or lower the ones that will adjust this surface at the flange. You do this over and over again and you rotate the shaft and eventually you will get this fairly even. Then if you want....repack the packing gland.
12 years 4 months ago #2914 by Emergpa1
Replied by Emergpa1 on topic Re: shaft alignment technique
Right, one thing I did not understand is you don't take the bolts all the way out you just loosen them slide the shaft back then slide it back on until it meets. don't tighten the bolts that yet, then turn it and see if it is even all the way around. I initially thought that you had to take all the bolts out but you only loosen them. About halfway.
Yenmar recommends replacing motor mounts every three years. But there is a way to check them. There is a certain amount of clearance that should be above the rubber and below the middle part of them out. Incredibly after all these years mine was still okay, but I still intend to replace the motor mounts. There is a bit of vibration that I would like to limit
You're getting into those kinds of things you probably want to get a good reference.
12 years 4 months ago - 12 years 4 months ago #2915 by PlumBob
Replied by PlumBob on topic Re: shaft alignment technique
Hayden, that's a good explanation of the process. Thanks! Isn't there a pictorial of changing the rubber mounts around here someplace? That sounds like a good project (another project) for me in the fall.
Last edit: 12 years 4 months ago by PlumBob.
12 years 4 months ago #2919 by hayden
Sam and all:
I do have a photo album of all the engine work I did, part of which was replacing the motor mounts. The 59 photo essay is here:
ipyoa.com/photos/62-hayden/album?albumid=168
Time to create page: 0.109 seconds
We have 2164 guests and one member online
