Engine overheating! I need answers
  • capediver714
  • capediver714's Avatar Topic Author
14 years 9 months ago #1007 by capediver714
Engine overheating! I need answers was created by capediver714
Went for a sail last night and when I was motoring back into the harbor, my engine started to overheat. Smoke was coming out of the engine compartment. Luckily I had a good enough wind to shut it off and sail back onto the mooring. Im new to boat engines but when I took a look it seemed like there was damage to the exhaust elbow. When the engine was running, there was plenty of water spitting out of the back of the boat, but the elbow joint on what Im guessing is the mixing component was so rusted it broke off in my hand. Anybody know what Im talking about or what its called, or where I can find a replacement part? Cost? Difficulty of installation? Anything would be helpful....
14 years 9 months ago #1008 by hayden
Replied by hayden on topic Re: Engine overheating! I need answers
The part you are talking about is the exhaust mixing elbow. You can see photos here:
ipyoa.com/photos/62-hayden/album?albumid=118
That is what they look like when they clog up. These usually need to be replaced at 10 years.
The engine part PDF for my engine 3JH2E can be seen here:
ipyoa.com/docs/doc_download/6-3jh2e-mixing-elbow
What you will need to do is call your local yanmar parts supplier and get the right one for your engine.
14 years 9 months ago #1009 by Bucky205
Replied by Bucky205 on topic Re: Engine overheating! I need answers
Overheating can be caused by a couple of things. If you are pumping water most likely the cooling jacket and elbow are corroded through. I had to replace mine last year. While it is apart check the heat exchanger cooling jacket that is connected to the mixing elbow. The jacket tends to corrode through right before where it enters the elbow. If you are loosing coolant the cooling jacket is definitely corroded through as well. Other than parts which cost about 1K for the elbow jacket and seals the replacement is not that bad. If you add coolant and the jacket is leaking it tends to run down into the engine, then the engine hydraulic locks and you have to get the coolant out before it will crank. If you need PM me and send a number and I can talk you through the replacement.
Chuck
  • capediver714
14 years 9 months ago #1018 by capediver714
Replied by capediver714 on topic Re: Engine overheating! I need answers
Ive been trying to do some research and Im thinking the heat exchanger is not the problem. Im not sure what this piece is called, but hoping one of you might. Its a Volvo Penta MD7A engine, not a Yanmar. The piece that broke I believe is part of the exhaust system, because when I turn on the engine (I ran it just for a minute to see if I could identify the problem), exhaust and a small amount of water come out of the piece that broke off. From that piece, there is a hose that runs to what I believe is the bottom of the heat exchanger. I took some pictures of the part where the piece broke off, and a picture of where that hose runs. This part is oval and cylindrical and bolts to the engine right above where the propeller shaft comes out of the engine.
  • capediver714
14 years 9 months ago - 14 years 9 months ago #1019 by capediver714
Sorry for the small pics, here are better ones.
Last edit: 14 years 9 months ago by hayden.
  • capediver714
14 years 9 months ago #1020 by capediver714
Does a water-cooled exhaust bend sound right? I havent been able to find one that looks like mine, but I have been searching nonstop and this seems like its the closest thing to mine. Could a crack in this cause the engine to overheat?
14 years 3 weeks ago #1405 by Barney1964
Replied by Barney1964 on topic Re: Engine overheating! I need answers
Hi CapeDiver 714
we had a similar problem with our original 4 series Yanmar 50 in our 1998 IP40 - on the 'Admiral's' first trip.... being part 2 of the delivery on Australia's eastern seaboard.
Transpires that there was corrosion in the aft end of the exhaust manifold housing (the box that houses the heat exchanger). The Brisbane based Yanmar specialist mechanics hypothesised that it was from a drink coming through the transom and up the exhaust. I dunno about other IPs, but on the 40's it's one hell of a big roller coaster loop to get up and over.
Anyway, there was an old elbow amongst all the gear, which the previous owners (owned her since 2007) got with the boat.
Anyway, the housing (but not the heat exchanger) needed replacing.
The cost of the part was about $1900 AUstralian Dollars, from Japan .... near enough to the same in US Dollars.
However it all seems good for now - finger's crossed.
(And yes, she was pumping water and all that - just the temperature was going from zero to off the dial after about 3 minutes running).
I'd be interested to hear what others thing - I attribute it to age.
Time to create page: 0.329 seconds
We have 1113 guests and no members online
