Garmin 541s depth reading problems
  • silent
  • silent's Avatar Topic Author
9 years 2 months ago #5689 by silent
Garmin 541s depth reading problems was created by silent
My Garmin 541s has never accurately or consistently worked in shallow water. I have installed the latest software, checked and rechecked all connections and did everything that Garmin tech helped had recommended to no avail . As soon as we sail into water 6 to 8 feet deep, the depth readout begins to blink and then will sometimes freeze at 2.5 feet. Any ideas?
9 years 2 months ago #5690 by hayden
Replied by hayden on topic Garmin 541s depth reading problems
John:
I had a similar problem with my new install. I found the problem to be the depth sensor which was replaced and then it all worked perfectly. Most of these marine sensors are made by AirMar, airmar.com/ so maybe you can find out the model you have from there.
airmar.com/productinfo.html?category=MT&...Marine%20Transducers
My B&G network of NMEA 2000 uses the Airmar DST800. It was brand new and would not show water below 10 feet. I ran that from Florida all through the Exumas to the Turks and Caicos where I was shipped a new one. I plugged it in and it work perfectly. Go figure.
airmar.com/
  • silent
9 years 2 months ago #5691 by silent
Replied by silent on topic Garmin 541s depth reading problems
Thanks. I have the DST800, my second one, and the problem persists. Airmar blames Garmin. Maybe I'll try another one. Did Airmar credit you for the new unit?
9 years 2 months ago #5692 by hayden
John:
My B&G rep worked with me and acquired a new DST800 from Airmar and sent it to me enroute. No charges! He works with Mack Sails which is where I bought all my gear.
  • silent
9 years 2 months ago #5697 by silent
Called Garmin today; they suggest setting the frequency to 200 for shallow water and dropping the gain down to 45. I let you know if this works.
  • silent
9 years 1 month ago #5741 by silent
Depth reading still not working even after changing settings to Garmin suggestions.
Time to create page: 0.134 seconds
We have 1310 guests and no members online
