engine movement
12 years 2 months ago #2816 by mrrgy
engine movement was created by mrrgy
Does anyone know? If engine mounts were defective of loose and boat was moving forward, at high rpms, which direction would the engine want to move? forward or aft?
12 years 2 months ago #2818 by hayden
Replied by hayden on topic Re: engine movement
We had broken the port forward side engine mount. We ran for maybe a year and 1000+ miles before we found it. The motor would twist and shake more. The mount stud broke under the tang and was only found by prying up with a crow bar lifting it.
If all 4 mounts broke while motoring, the motor would push forward while in gear running forward. It would move aft in reverse. It would drag aft in neutral due to the prop dragging.
Do you see your motor moving?
Does your motor shake?
Are the mounts bottomed out?
Time to create page: 0.207 seconds
We have 3111 guests and no members online
