Packet racket
14 years 9 months ago #1237 by Skye
Packet racket was created by Skye
Our IP 35-159 has rudder vibrations under power - which seem to be increasing. Any suggestions?
14 years 9 months ago #1238 by Sailbatical
Replied by Sailbatical on topic Re: Packet racket
I have an ip 38 1989 and I am also experiencing noises from the steering/ rudder. It is not exactly a vibration rather it occurs when steering under power- odd??
14 years 9 months ago - 14 years 9 months ago #1240 by hayden
Replied by hayden on topic Re: Packet racket
Skye:
This happens from prop wash and prop water pushing over the rudder. It not a real big deal, but you may want to inspect your rack and pinion gears under your seat. Take your wheel and with the seat open, and at the dock or anchor, work the wheel back and forth about 1/4+ turn in each direction. Watch the rack and the rudder post at the base to see if you have any real movement. I doubt that you will. If you see the bearing on the bottom loose or the rack loose then these could be the issue, but I have never heard of that. It most likely is prop water over the rudder.
Does it vibrate much when sailing? Ours will but only at 7-8 knots high speeds.
Last edit: 14 years 9 months ago by hayden.
Time to create page: 0.150 seconds
We have 2278 guests and no members online
