Chain and Shackles, WLL
  • hayden
  • hayden's Avatar Topic Author
  • Away
  • Moderator
  • Moderator
15 years 7 months ago #698 by hayden
Chain and Shackles, WLL was created by hayden
I just received my HamiltonMarine.com catalog and I am reminded of a very important topic: anchor chain and shackles WLL, working load limits!
Many of us use Hot Galvanized Grade 40 Chain, HT, 5/16" which has a WLL of 3900 lbs. Then we go and use a regular 3/8" shackle which has a WLL of 2000 lbs. Mix in an anchor chain swivel or eye swivel and we could have a real weak link in our anchor chain connection.
According to Hamilton Marine, you should always go up one size from the chain to the shackle. For example: 5/16" chain uses a 3/8" shackle (5/16" chain, 6/16" shackle, one size up)
In this example, the 5/16" grade 40 chain will have a WLL of 3900 lbs. This 3/8" Crosby High Test Screw Pin Shackle will have a WLL of 4410 lbs. So, we now have a shackle that is stronger than the chain! Exactly what we want.
If you need larger chain, then the next size up would be: 3/8" Grade 40 Chain with a WLL of 5400 lbs. Then the shackle would be 7/16" Crosby HT screw pin shackle with a WLL of 5880 lbs. Again, this shackle is stronger than the chain.
My question to you is.....do you know the WLL of your anchor chain shackle? Do you know if you have a Crosby High Test Screw Pin Shackle?
You should look for USA made shackles from "the CROSBY group inc" which are available from HamiltonMarine.com in Maine.
15 years 6 months ago #732 by cnelson
Replied by cnelson on topic Re: Chain and Shackles, WLL
Is your photo just an example? It was my understanding that the red pinned shackles were not nearly as high a wll as the HT shackles. This is the link Norm sent me a few years back.
store.hamiltonmarine.com/browse.cfm/4,18244.htm
  • hayden
  • Away
  • Moderator
  • Moderator
15 years 6 months ago #733 by hayden
Replied by hayden on topic Re: Chain and Shackles, WLL
Yes, you are right, I was only using that as an example. The key is to use an HT shackle. Thanks for the link, I added the pictures here as well...
14 years 9 months ago #1175 by eau-de-vie
Replied by eau-de-vie on topic Re: Chain and Shackles, WLL
This caused me to check what I have. I had just added a windlass this summer with 200' of chain. In checking, the shackles had a WLL of only 1 Ton vs. 2 Tons for the chain. In looking at my secondary anchor (a CQR with 80' of chain) I had a 3/4 Ton shackle - Yikes! All have now been replaced.
  • hayden
  • Away
  • Moderator
  • Moderator
13 years 9 months ago #1773 by hayden
I am replacing my shackles with new ones, due to age, no other reason. Here is the direct link to the HT CROSBY SHACKLES and their information. This is what I am using on my G4 HT 5/16" Chain.
SHACKLE ANCHOR 3/8" USA 2TON HI TEST SLVR PIN 105393
ANCHORING / SHACKLES, SWIVELS & LINKS / SHACKLES
3/8" HT Shackle:
store.hamiltonmarine.com/browse.cfm/shac...105393-/4,18243.html
All Shackles:
store.hamiltonmarine.com/browse.cfm/shackles/2,1034.html
  • hayden
  • Away
  • Moderator
  • Moderator
13 years 9 months ago - 13 years 9 months ago #1774 by hayden
Here is one more resource for these Crosby HT Shackles:
www.riggingwarehouse.com/products/RIGHAR...D01@@2e22@@2e04.aspx
G-209A Crosby® Alloy Screw Pin Anchor Shackles are forged alloy steel-quenched and tempered, with alloy pins. These shackles meet the performance requirements of Federal Specification RR-C-271D, Type IVA, Grade B, Class 2, except for those provisions required of the contractor.
PDF file on CROSBY Shackles
File Attachment:
File Name: Crosby_G-2...pecs.pdf
File Size:587 KB
Last edit: 13 years 9 months ago by hayden.
  • hayden
  • Away
  • Moderator
  • Moderator
13 years 8 months ago - 13 years 8 months ago #1835 by hayden
Here are some photos of these CROSBY SHACKLES. These are the 3/8" shackles for use with 5/16" chain. WLL working load of 2T, two tons, 4,000 lbs.
I bought these from:
Last edit: 13 years 8 months ago by hayden.
11 years 10 months ago #3674 by Rwirtz
Replied by Rwirtz on topic Re: Chain and Shackles, WLL
Any suggestions as to what swivel to use with 5/16 inch chain and Crosby HT 3/8 inch shackles?
  • hayden
  • Away
  • Moderator
  • Moderator
11 years 10 months ago #3678 by hayden
I would avoid the use of any swivel. The center pins cannot be inspected.
I do not have one.
11 years 10 months ago #3679 by Rwirtz
Thanks. Plan on getting a Rocna 25 next week and will just use the HT shackle to attach it to the chain.
11 years 6 months ago #3833 by Sailkestrel
Replied by Sailkestrel on topic Re: Chain and Shackles, WLL
Did you up size your chain to 3/8" or stay with the 5/16" when you purchased your new Rochna 25?
Clarence
SV Kestrel
  • hayden
  • Away
  • Moderator
  • Moderator
11 years 6 months ago #3834 by hayden
Clarence
We kept our 5/16" chain with our 55lb Rocna. It is working well.
Hayden on anchor Marsh Harbor Abaco
11 years 6 months ago #3836 by Sailkestrel
Thanks Hayden,
We want to up size and replace our CQR with a Rocna and like the idea of going up two sizes. We plan to add more chain and will switch to 3/8 later. It will also require a new chain gypsy for our Lofrans. $$
Clarence
SV Kestrel
IP35#18
Time to create page: 0.459 seconds
We have 2041 guests and one member online
