Topic Author
Topic Author
Topic Author
Here you can download a pattern. Cut it out and paste it to cardboard. Then you can see if it fits your boat. That is what I did before I purchased.Tikkun wrote: Thanks for the picture. I'm not sure how to upload my picture on this forum...but my bow rollers are on the side of the pulpit and several inches back from the front edge.
Topic Author
Topic Author
Topic Author
Topic Author
I don't think it will fit. can you add a bow roller to your bowsprit? The attachment is not a big deal. you are just drilling all the way through the bowsprit, buying some large SS bolts, and use some large washers to act as backing plates. or you could take the bow roller to a machine shop so they would have a pattern and have them make a stainless steel backing plate (but the problem with this is your drilled holes will not match the pattern of your bow roller because you cannot get the angle of your drilling exactly right. does that make sense?, if not let me know and i will try to explain and give the solution), or you could make your own out of 1/2 inch teak plank sealed with epoxy.Tikkun wrote: Thanks for looking. I'm a bit stymied too! I'm trying to build a model from the pattern on the rocna site...but I would prefer the actual anchor
Topic Author
Good advice PlumBob.PlumBob wrote: Makes perfect sense.... My setup is like Emergpa1's except I have 2 bow rollers - one on each side of the forestay. My (only) anchor is currently in the stbd slot. IP sells an enlarged and improved anchor roller setup for the bowsprit (at least I've been told they do. I saw a boat w/ anchor rollers that the fellow told me he had gotten from IP factory. Was a little larger overall and heavier gauge SS.)
I personally wouldn't make it out of teak. If I were going to try to add bow rollers to your boat, I'd place the top half (roller part) on top, mark the holes, and drill as close to perpendicular (both axes) as possible. Then put a piece of plywood or such under, and mark the holes through the holes I had drilled in the bowsprit. That way, the backer-plate holes DO match your bolts. Then have your machine shop cut your backing plate and drill per your pattern. Seal and mount, etc. I don't remember what the bottom of my bowsprit looks like. You might have to deal w/ the top attachment of the bobstay, for instance.
From your pix, it's obvious that your roller was designed to fit the side. It looks to me like there is one on the stbd side, too. Do you think they are through-bolted all the way through the bowsprit? That might complicate things, too - if there are holes (voids) instead of solid material. Nor do I know what the center of the bowsprit is made of. Questions, questions, questions.
But the process of adding bow rollers should be pretty straight-forward - except, again, for the configuration of the backing plates.
Of course, the universal answer to questions like what is the internal composition of the bowsprit is - "Ask the factory." Karsten is full of information, and shares liberally. This email address is being protected from spambots. You need JavaScript enabled to view it.
Edited to add - sorry, I didn't fully read that you really want to avoid adding a new roller. THAT really makes sense to me.
Topic Author
We have 1596 guests and one member online
Island Packet and Island Packet Yachts are registered trademarks of IPY (Island Packet Yachts, Inc.). IPYOA and The Island Packet Yacht Owners Association, have no affiliation with IPY, the Island Packet Yacht Company. Throughout our IPYOA Facebook Group and on this IPYOA.com website the terms Island Packet and Island Packet Yachts are used for identification purposes only. This use is FAIR USE and NOMINATIVE. We are NOT a yacht manufacturer we are a yacht owners group.
