Lightning protection and grounding system for IP 27
10 years 2 months ago #5117 by gero
Hello everyone!
I unstepped the mast of my IP 27 to rewire and change the wind transducer, and renew the VHF antenna. I read in the manual that all Island Packets come with a grounding system that connect the mast to the plates and down the engine and shaft, which is great. However, after removing the mast I haven't seen anything alike; is it connected to the mast step? Has anybody seen it?
I'm new to Florida, and am quite scared of lightnings... I got trapped in a squall two months ago with lightning all around me, it wasn't fun at all....
Any help is appreciated!
10 years 2 months ago #5118 by Emergpa1
there should be a green wire (cable) attached to the mast plate at the base of the mast.
I'm with you, I think lightening is the thing that gets me most nervous. To get control of my fear I remind myself that if I do get struck, and it's fatal, I'll never know what hit me.There one moment, gone the next. Considering all the ways I might leave this world, a fatal lightening strike has got to be one of the better. It sounds rather ridiculous, but it works for me.
The following user(s) said Thank You: gero
10 years 2 months ago #5120 by hayden
Geronimo
The mast is grounded also by the shrouds and stays which connects to the chain plates which are connected to the grounding green wires. I had the IP 27 for 10 years and I do not recall a wire on the step plate. So, your mast is grounded.
10 years 1 month ago #5137 by gjones04
Geronimo,
Hayden is correct. As per the original design shown in the IP 27 Owners Manual (available in the file download area on the IP Home Port website), there is no ground bonding wire to the mast step and, in fact, the mast head is grounded only through the starboard shrouds chainplate and the starboard backstay chainplate.
I believe the mast grounding system for later IPs remains much the same. Certainly our 380 bonding system has green bonding wires for mast grounding going only to the port shrouds and backstay chainplates. It's not clear to me why the mast step is not grounded and also why the starboard backstay and shrouds chainplates and the headstay fitting are not grounded, but that's as Bob Johnson intended.
It may be of interest to know that, at least for us, the grounding system as designed has saved the boat from catastrophic lightning damage. Last month while on our mooring on the Chesapeake we took a direct strike to the masthead that destroyed the VHF antenna and windex, then apparently traveled down the VHF coax cable, the grounded port upper shroud, the grounded port backstay and also the headstay and genoa foil (not connected to the bonding system, so not clear where the current ended up), and then apparently largely via the bonding wiring system to ground (i.e. sea water) through the bronze hull fittings, propshaft and propellor. There is no visible damage to the hull, chainplates, or interior, but there was direct damage (heating or arcing) or indirect damage by voltage surge or induced currents to some standing rigging, all electronics, and much of the electrical equipment and systems. Even the house and engine batteries, refrigerator compressor, and bilge pump float switch were damaged. Total diagnostics and replacement parts and labor exceeds $40,000. I can provide a list of the repair/replacement work needed if anyone is interested.
The good news is that we now have a lot of new equipment and standing rigging and great new communications, navigation and sailing instruments - all covered by our insurance. It may also be of interest that our insurers covered the claim 100%, new for old, with no deductible and no depreciation. Certainly a recommendation from us for insurance from Boat US.
Graham
Graham Jones
IP 380 Indigo
West River, MD
Moderators: acajun, shawnee
Time to create page: 0.103 seconds
We have 1923 guests and no members online
