High Tach, Intermittent Battery Light
  • capjules
  • capjules's Avatar Topic Author
10 years 8 months ago #4400 by capjules
High Tach, Intermittent Battery Light was created by capjules
Hello,
My tach went high about 1000 rpm's for about thirty seconds, then later in the day the battery light was on intermittently, the longest it was on was about 5 minutes.
Back in the slip everything was normal so I could not trouble shoot.
Is it possible the high tach and battery light were related or just coincidental ?
Jules
10 years 8 months ago #4401 by hayden
Replied by hayden on topic High Tach, Intermittent Battery Light
These sound like simple electrical connections / contact issues. Look at the top front of the transmission and you will see a plug with two wires connected to it. This is the tach sensor. Pull these wires, they are simple press on fittings that press onto a spade. Spray them with WD40 or Boshields corrosion block spray and then press them back on. Make sure they are tight, if not crimp them tight. This should fix your RPMs. As of the battery light, I am not sure what or where that is, but it has to be the same issue. Simply check the connections, clean, and re-tighten. Loose wires casue all kinds of problems and we look at as tighten all we can every year.
  • capjules
10 years 8 months ago - 10 years 8 months ago #4402 by capjules
Replied by capjules on topic High Tach, Intermittent Battery Light
I call it the battery light on the engine instrument panel also known as the charge light. Some panels that have symbols by each red light show a battery symbol, others name it the charge light.
Last edit: 10 years 8 months ago by capjules.
Moderators: acajunshawnee
Time to create page: 0.105 seconds
We have 2481 guests and no members online
