Passive ventilation always comes from the engine itself. Our 4JH2E engine is 100 cubic inches. At 2500 RPM it draws in about 140 cubic feet of air per minute through the air intake. That completely cycles the air in the engine compartment about 6 times a minute. That air comes from other parts of the boat (bilge, lazarette, and boat interior). I've got an aftermarket 100 amp alternator with the regulator inside the engine compartment but with no special ventilation for either. Both have worked fine for 10 years since installed. So not sure if an additional dedicated blower is really needed. Wouldn't hurt though if you can get yours running. I wouldn't loose much sleep over it if you can't.
