IP 35 vs IP 350
  • peloquin
  • peloquin's Avatar Topic Author
13 years 11 months ago #1581 by peloquin
IP 35 vs IP 350 was created by peloquin
I am planning on selling my IP 27 and buying either an IP 35 or a 350. I would be interested in hearing what the operative, qualitative, etc differences are between the two. Thanks
13 years 11 months ago - 13 years 10 months ago #1584 by Hayden2
Replied by Hayden2 on topic Re: IP 35 vs IP 350
The 35 is an older model and is more similar in size to the 380.
The 350 is a newer model is more similar to the 32.
The 35 uses the same galley as the IP40
The 350 uses a smaller galley, 2 burner stove but a better ice box.
The 35 has traditional bunks, V and Qtr
The 350 has island bed forward and sideways bed aft
The 35 costs less than most 350
The 35 has full engine access with the engine at floor level
The 350 has the engine lower and under the Qtr berth and more aft
The bow is higher on the 35 and the sheer line is more pronounces
The sheer line was removed on the 350 and most IPs w/XX0 making the bow lower and the cabin top higher
For me, I prefer the older IPs due to this lost sheer line.
I do like the lower engines for quiet and less sound, but thats it.
I do like the newer ice boxes of the 350
The island beds are nice at anchor but would not work as well under sail
It really is a toss up. You need to get onto each boat and feel the space and the set up. Then once you feel the space next is the budget. Most of us will buy the most boat our budget can take.
Enjoy the shopping, it is a fun time...
Last edit: 13 years 10 months ago by hayden.
13 years 11 months ago #1586 by bobbster
Replied by bobbster on topic Re: IP 35 vs IP 350
We are the proud owners of an IP350 and have extensive offshore experience and can provide some additional info if you are interested.
We do not have an island bed on our 350. We have an offset forward berth that works well offshore. But the best sea berths are in the salon with lee cloths installed.
In the aft cabin the Pullman berth (athwart ships works well) at anchor and offshore. We've used a mid line lee cloth in the aft cabin on a round trip to Bermuda and on two DELMARVA circumnavigations. On our blue water trip to the Caribbean it was not required but the aft cabin turned out to be the best place to sleep!
There is more space in the salon behind the seat backs with mid level shelving. More room for spares, provisions, just more useable space.
There are two fulls size lazarettes on the 350 that to me are a big plus. Great storage and easy access to the water heater and steering gear.
The reefer/fridge is also aligned side to side - so you have less effect from solar radiation on both the reefer and freezer. We use the outboard side of the box as our reefer and the inboard side as a full freezer. Have added extra insulation but the results are amazing.
There is room in the factory installed battery box for up to 6 GPL-31 AGM Batteries - no need to extend cable and make remote connections to other batteries in other locations.
A stay sail on the Hoyt Boom is a great addition when offshore in higher winds or when you are forced to motor sail into chop/slop and winds nearly on the nose.
Access to the bilge pump is much easier on the 350 and the shower sump pump/strainer is also easily accessed.
Compare the boats and decide which is right for you. They are both great products from IP!
  • peloquin
13 years 10 months ago #1588 by peloquin
Replied by peloquin on topic Re: IP 35 vs IP 350
thanks for your time and insight
Time to create page: 0.132 seconds
We have 1267 guests and no members online
