in mast furling mainsail won't come out properly
  • talisman420
  • talisman420's Avatar Topic Author
16 years 5 months ago #270 by talisman420
We have had a problem since the beginning in trying to get the mailsail to come out normally. It seems to pucker, especially at the top. We have Charleston Spars furling, our Ip is a 2003.
Does anyone have any information to help here? Thanks rw
16 years 5 months ago #271 by a Guest
RW:
Can you be a little more specific on the problem?
There are several things that contribute to the RF main not behaving well and you will have to play with them in order to optimize the handling of the sail.
1. Leech Line
2. Boom angle
3. Halyard Tension
4. Furling technique
Once 1 - 3 are sorted out - We never furl the sail using a winch. Try to maintain some pressure on the outhaul as you furl the sail. This will make sure that the sail is properly wound on the foil without any baggy or bunched spots. Have found more often than not if we did not furl the sail properly that it can be a problem when we go to set the sail.
Admiralty Bay, Bequia SVG
Time to create page: 0.075 seconds
We have 1131 guests and no members online
