Clogged hose
  • oneeyedparrots
  • oneeyedparrots's Avatar Topic Author
14 years 7 months ago #1111 by oneeyedparrots
Clogged hose was created by oneeyedparrots
The hose between our macerator pump and thru-hull has become clogged on our IP 420. Any ideas for unclogging it would be appreciated. I am concerned about using a "snake", as I don't want to damage the anti-siphon valve that is located behind a locker wall (I really don't want to have to dismantle the cabinetry.
14 years 7 months ago #1114 by hayden
Replied by hayden on topic Re: Clogged hose
Ken:
I doubt that you could damage the vent as it is all tube and a snake would not go into the vent area. I also doubt that a snake would make that bend as it is a total u shape. The clog could be in the head around the pump as maybe taking the head apart might be required. You could blow it out with a garden hose, maybe, or an air compressor or the dinghy pump. Sometimes is the boat is on the hard you can work from the other side. Eventually if not of this works, you will have to take the hose fittings off...
Not an easy task.
Time to create page: 0.076 seconds
We have 1222 guests and no members online
