Thinking of buying our first IP
  • schulerzoo
  • schulerzoo's Avatar Topic Author
15 years 10 months ago #447 by schulerzoo
Thinking of buying our first IP was created by schulerzoo
What to Know before you buy?
Hello to all you IP owners.
We are contemplating joining the club with the purchase of an IP37 or 35. We will be using it for the next couple years locally here in Los Angeles, visiting channel islands etc, till the kids are are in college, then its off to explore. I keep reading about the full keels and how hard they make it to reverse the boat or turn. What are your thoughts. Will this be a problem in our tight slip or when exploring far away ports/marinas?
Also, we are interested in the 35 and 37. Besides size, are there any other advantages or disadvantages between the two models that you can think of? Also we want a newer boat. What years do you recommend? We currently have our 37 foot Beneteau for sale.
Thanks for the input.
Jill and Ed
Jill and Ed
15 years 10 months ago - 15 years 10 months ago #448 by a Guest
Replied by a Guest on topic Re:Thinking of buying our first IP
I have an IP350 (bought in 1998) and find that once you learn to back the boat and understand how it handles it is not a problem.
Not sure what you mean about turning the boat as well - it turns fine.
I personally think that newer is better as there are minor improvements in each production year of the boats. Since the 37 was introduced to replace the 35 it is a newer production boat but have no personal experience aboard either.
Start looking at both of these models and do a walk around comparison.
Punta Gorda, Fl / Caribbean
Last edit: 15 years 10 months ago by a Guest.
15 years 10 months ago #453 by hayden
Replied by hayden on topic Re: Thinking of buying our first IP
Jill and Ed:
We own an IP35 and have sailed her for 10 years. The 37 is the upgraded model of the 35 but they are very similar. One negative of the 37 vs. the 35 is that the bow is less broad, so the v-berth is tighter on the 37 than the 35. Of course this would be better for powering and sailing, but negative for sleeping space. The other item I noticed is that the 37 bow is lower than the 35! This is obvious when I view the 37 docked next to the 35 in my marina. During the progressions of IP design, the ZERO boats, ones with a zero in their numbers, 320, 350, 370, etc. the designer lowered the bows, removed the sheer line curve, and made the cabin tops higher off the deck. These items are a non item when looking at the 35 or 37 or 40. These older IPs have a beautiful sheer line, a bow that rises up, not flat, and a cabin top that is not so high off the deck, which makes it easier to step up AND off off. Every time I am on a 380, or 350 or 370, I nearly break my back steping down off the cabin roof to the deck because it is so much higher of a step than it is on the older IPs. This simply happened due to design line changes introduced into the Zero boats. When you lower the bow, straighten out the sheer line, and ALSO raise the cabin roof, you get an entirely different yacht. I will say that the newer designs have a bigger feeling inside, but I do not like the lines on the newer designs. Interesting note is that with the new model, the IP 460, the raised bow and beautiful sheer line has been returned.
As for backing up and docking, this is a big difference from your 37 Beneteau fin keel which drives as well aft as forward. These IPs you need to learn to warp then into slips, and also use the port prop wash which pulls the stern to port when backing. I have been backing IPs into a slip since 1991, and I still have good days and bad days. You will never back an IP down a long slip way like you can do with a fin keel boat. No way. You go in, spin to starboard ALWAYS, because reverse will help with that rotation, then back into your slip which needs to be on your port side. If its the other way, then use a starboard spring on the stern cleat and warp around the piling as you back up which will pull the bow to port.
These are ocean sailing yachts, meant for sea, and heavy winds, so thats what you are buying.
12 years 8 months ago #2324 by KevinW
Replied by KevinW on topic Re: Thinking of buying our first IP
Why wait... Go simple, Go small, Go now! Cut the dock lines and go... Ceal and I went from Channel Islands in December 2011 and haven't looked back. Planes and telephones work everywhere. For inspiration check out the blog at AlwayGoBlog.com
Kevin
12 years 8 months ago #2327 by Emergpa1
Replied by Emergpa1 on topic Re: Thinking of buying our first IP
I like your idea Kevin. My motto too!
I'm curious, why are you are selling your Benetau Jill and Ed? Are you needing a shallow draft where your sailing?
Keith
Time to create page: 0.133 seconds
We have 1552 guests and no members online
