- Thank you received: 12
Side-Power Bow Thruster Troubleshooting and Maintence
14 years 5 months ago #1479
by Augydoggy
Side-Power Bow Thruster Troubleshooting and Maintence was created by Augydoggy
I've been having some issues with my Side-Power SP75 bow thruster lately. I had trouble finding helpful information on the website or in the manual so I called IMTRA and discussed what was going on. The tech sent me some really good guides for maintenance and troubleshooting. I've attached three PDF's here to share with the group.
Tom
IP 420-35
La Vida Dulce
Tom
IP 420-35
La Vida Dulce
14 years 5 months ago - 14 years 5 months ago #1480
by Augydoggy
Replied by Augydoggy on topic Re: Side-Power Bow Thruster Troubleshooting and Maintence
Here's one more. This was a list of suggestions sent to me by the tech at IMTRA.
Do This First – Troubleshooting Tips for the Side-Power Bow Thruster:
• Check the operating voltage on the batteries, it should be 1 to 1.5V higher than at the thruster, a larger voltage drop then 1.5V should be looked into.
• Check the rated CCA of the batteries, at the rated 1045 CCA at zero degrees Fahrenheit, operating volts at the batteries should be in around 11 – 11.5V.
• Remove the motor from the boat and blow it out with compressed air (use respiratory protection).
• Check to make sure none of the brushes are sticking.
• Remove the prop and bring it to the surface for complete cleaning and anti-foul painting.
Tom
IP 420-35
La Vida Dulce
Tom
IP 420-35
La Vida Dulce
Last edit: 14 years 5 months ago by Augydoggy. Reason: Was unable to attach a docx. file
14 years 5 months ago #1481
Replied by hayden on topic Re: Side-Power Bow Thruster Troubleshooting and Maintence
Tom:
Thank you, this is fantastic info and the PDFs are very helpful and clear. I am sure this will help many owners with the bow thruster troubleshooting process. Thank you for sharing this.
- [email protected]
13 years 11 months ago #1753
by [email protected]
Replied by [email protected] on topic Re: Side-Power Bow Thruster Troubleshooting and Maintence
Thanks for the information, will do this soon.
13 years 3 months ago #2165
by dougklay
Replied by dougklay on topic Re: Side-Power Bow Thruster Troubleshooting and Maintence
Wow, this last guide really helped out. Spent a good part of the day opening things up and found the main fuse for the thruster had gone. Trip to West Marine and got lucky to find the large fuse. Smiled, replaced it thinking all was good. Still no operation.
Original owners manual is really fuzzy on the parts/connections on the motor, and the current location of the unit in the bowels of the boat makes it no easier. Went through the steps identified here and found the solenoids bad.
11 years 5 months ago #4069
by capjules
Replied by capjules on topic Re: Side-Power Bow Thruster Troubleshooting and Maintence
my voltage at the batteries drops from 12.7 to 11.2 when running the thruster, is that too much ? do I need new batteries ?
Time to create page: 0.058 seconds
