B & G Repair and Service Tech
11 years 3 months ago #4163 by hayden
I have found THE B&G REPAIR MAN. His name is ...
David Bourque and you can contact him at shop at oceaninlay dot com
He emailed me and said....
Hi Hayden,
Yes we can rebuild you autopilot,
A seal kit and brushes would be no problem,
The shipping address is
Precision Marine Services
719 Bulgarmarsh Rd
Tiverton Ri 02878
401 662 7317
You may see other services we offer at www.oceaninlay.com
Here is my ram rebuilt and serviced!!!! Next I will send him my spar that is installed now. This unit received new seals and new brushes plus a paint job and it was tested under load. It's good as new. He says these are the best rams made.
I have to agree.
The following user(s) said Thank You: badboo, Paulsailor
10 years 9 months ago #4651 by Emergpa1
Hi Hayden,
Just curious, but I thought you did your on repair several months ago? What happened?
Keith
hayden wrote: I have found THE B&G REPAIR MAN. His name is ...
Hi Hayden,
719 Bulgarmarsh Rd
Tiverton Ri 02878
401 662 7317
I have to agree.
10 years 9 months ago #4652 by hayden
Keith
I bought the B&G brush kit. I took apart the motor and noticed it needed soldered into the board. Then I found this repair guy and he does lots of these. So I sent it all to him. He repaired it and then.bench tested it. I now have that one shrink wrapped and stored in my spare parts onboard if I need it.
The B&G rams are great.
9 years 2 months ago #5754 by Horst
Replied by Horst on topic B & G Repair and Service Tech
Hayden, I had my B&G T2 RAM repaired in California about 3 years ago, it is already leaking again after maybe 6000 nm. How has your rebuild ram done so far and how much did the repair cost ? I am trying to decide if I should just buy a new one ?
9 years 2 months ago #5756 by hayden
Horst:
My RAM is still running fine, and I have my second rebuilt in the bow storage. I have no problem with the rebuild by David Bourque. I would use him again. I do not recall the price.
Time to create page: 0.071 seconds
