WIFI SYSTEM THAT WORKS GREAT!
  • a Guest's Avatar Topic Author
16 years 11 months ago #185 by a Guest
WIFI SYSTEM THAT WORKS GREAT! was created by a Guest
If you are looking to add a WIFI antenna system to your boat you may want to investigate the system offered by Dalton Williams a cruiser who owns the S/V Quietly. He has set up an informative web site wififorboaters.com that provides excellent information on the system he has put together. We installed the system while we were in Trinidad last month and I am very pleased with the results. We are currently anchored off Hog Island, Grenada and are tied into a WIFI system over a mile away with excellent speed. An important feature of Dalton's system is the fact that it eliminates expensive antenna cables by tying the computer to the antenna using CAT5 no loss wiring. WIFI System Details
16 years 11 months ago #186 by hayden
Replied by hayden on topic Re:WIFI SYSTEM THAT WORKS GREAT!
Could you review your link because it does not come up for me. WiFi on boats is one of my favorite topics and I keep reading all I can about this. I need to install one as a back up, or secondary system to my Verizon broadband card. I know I will need a WiFi rig for outside of the US. Thanks for the info...
16 years 11 months ago #187 by a Guest
Replied by a Guest on topic Re:WIFI SYSTEM THAT WORKS GREAT!
Try the following address:
www.wififorboats.com/
Dave
16 years 11 months ago #189 by a Guest
Hayden:
Dave:
This system is based on the Bullet2 HP radio that I commented on and posted photos of some time back. Price is ridiculous - radio is $80, antenna is about $50, CAT5 Cable is is cheap and POE injector is about $5.
But the system is superior to anything I have tried previously.
Love my Bullet2HP
16 years 11 months ago #190 by a Guest
Bobby,
I agree that the individual components are available for a lower cost if you source them directly, however, many folks are not tech savvy and may need advice and guidance as they work their way through the process of installing and using the equipment. You have to also consider the cost of shipping from individual sources to the Caribbean (where I am now) can be very costly and incur additional ad hoc charges or fees that inflate the cost over a single source supplier. But like you said, this is an awesome system and no matter how your source it.
Kind regards,
Dave
16 years 11 months ago #191 by a Guest
Dave:
How much longer will you folks be in Grenada? We fly back to Grenada on 6 Nov. DO you need anything from back this way?
Any idea whick hot spot you are accessing off Hog Island?
I used to think that shipping was to steep but I just sent a 120w Kyocera Solar Panel there for $34.00 Took 7 days enroute via Tropical Shipping. Setup is straightforward and I can provide info for anyone interested.
My setup also includes a router on the boat so that we can share the connection with local boats of laptops on our own boat.
16 years 11 months ago #192 by a Guest
Bobby,
Coral Cove has two signals that can be used from the south side of the bay. Sounds like you found the right way to import thing into Grenada. We ordered two burners for our Princess stove and paid over $120 dollars for shipping and other fees. We used IWW as the receiving point and boy did those costs add up. The duty is only 2.5% but they found lots of other things to charge us for. We also purchased chain and other items this summer, however we sailed to Trinidad (Marine Warehouse) and as you know cost us almost nothing for shipping through them. You live and learn. We are heading to the Grenadines over the weekend and then head north to St. Croix for Thanksgiving so we will see you as we head south after some fun in the leewards.
16 years 11 months ago #193 by a Guest
Hayden:
You have the details of this WiFi Solution that I sent to you as a powerpoint or pdf document several months ago. Let me know if you want the config file for the radio and a detailed explanation on setup and use of the radio. It really is simple and way outperforms anything else I have seen to date.
Bobby :)
16 years 11 months ago #194 by hayden
Bobby:
Yes, I do have that from you in my "Bobby" folder along with many other documents you have sent me. I need to order this BULLET / WIFI set up and give it a try. It really does look like the best way to go. If anyone wants to read about this WIFI Bullet, see this:
www.ubnt.com/products/bullet.php
16 years 11 months ago #195 by a Guest
Hayden:
If you would like you can post the drawing on the documents page and I would be willing to send configuration file and setup info to anyone interested.
16 years 11 months ago #196 by groger
Replied by groger on topic Re:WIFI SYSTEM THAT WORKS GREAT!
With help from Bobby, I was able to build his Bullet-based wifi system. It's installed upstairs in my house and pulls in signals from all over the neighborhood. I'm working on a plan to mount it high on the davits or over the bimini when we return to the boat in January. We had a spare router at home so the only costs were for the Bullet radio, an antenna, the POI injector and a bit of CAT V wire. Easily less than $200
Glen
16 years 11 months ago #197 by hayden
Bobby:
I have various versions of your set up. If you can, please post your current documentation to the doc library. There is a section there for wifi and network docs. This is really cool stuff. Thanks again.
16 years 10 months ago #212 by margo
Replied by margo on topic Re:WIFI SYSTEM THAT WORKS GREAT!
Try this link..
Margo
s/v/ Windseeker
Margaret Dolan
s/v Windseeker IP 38-168
Port Kinsale, VA
16 years 10 months ago #213 by groger
Bobby,
Do you think that the height of the antenna/radio has a big effect? That is, should I be thinking of mounting it way up the mast and running cable or is it good enough to mount it above the dodger somewhere?
Glen
16 years 10 months ago #214 by a Guest
Margo:
This is the same system that we have been discussing and was originally referenced by Daniel Storey.
16 years 10 months ago #215 by a Guest
Glen:
It may make a small difference but I am not sure that the effort would be worthwhile unless you had the mast off the boat for something else. You would not want to just let the CAT5 cable down the mast without running it in one of the conduits inside the mast. It may be very difficult if not impossible to pull the cable through the conduit with the mast in place.
I have my antenna mounted off my davits just above the Bimini and it works fine.
16 years 10 months ago #216 by hayden
Update on BULLET2HP as of Oct 2009. The company that makes the Bullet WiFi radio is having a supply chain problem and they this model is out of stock until late Dec 09/Jan 10. I have been given a refund on my order and will be waiting until they arrive. Here is a summary of the various models and their power and their networks:
Ubiquiti Bullet2HP: 802.11b/g 800mW Indoor/Outdoor CPE $79
Ubiquiti Bullet2: 802.11b/g 100mW Indoor/Outdoor CPE $39
Ubiquiti Bullet M2 HP: 802.11b/g/N 600mW Indoor/Outdoor CPE $79
Ubiquiti Bullet M5 HP: 802.11a/N 600mW Indoor/Outdoor CPE $79
HP stands for high power, I guess, and you can see the 2HP is for b/g networks where the 2 is for b/g networks by way less power. Then if you want to use N protocol you would need the M2 or M5 radio.
So, as Bobby pointed out, the best seems to be BULLET2HP since it gives you the most power and covers 802.11 b/g networks.
Outstanding work on this WiFi system Bobby, now if I can only get the radio. I have all other parts. I will update as I learn more on the Bullet2hp.
Bullet2HP Data sheet / link:
16 years 10 months ago #218 by a Guest
Hayden:
Suggest that you get an order in so that when the back orders are filled that you receive your device - if not you may not get one.
To clarify your earlier post:
These two radios work very well (the 100mw version not being as good as the 800 mw version due to power output only).
The M2HP is not advised at this time for our application - this is primarily intended for point-to-point applications and the operatiing system does not perform well at all with 802.11b/g networks.
This radio does not work for WiFi period - it is a 5GHz version of the Bullet 2 (2GHZ) and will not work at all with WiFi which operates in the 2GHz range. This radio is intended for point-to-point radio applications.
I had a backorder filled about 1 month after I placed the order - with many of the WiFi providers using these radios and ordering them in bulk I would want to have an order sitting ready to ship when the radios are delivered to the vendors.
16 years 10 months ago #220 by hayden
Bobby:
Good point, I have placed an order to get in line:
wisp-router.com/
Bullet2hp, $79.00 + $7.95 shipping, they are in Kansas.
We will see how long this takes.
16 years 10 months ago #221 by a Guest
Hayden:
Think that is a good idea - I've noticed 3 - 4 integrators that sell complete systems - all show out of stock - so better to have a placemark in. I just upgraded the firmware on my HP - was worried -thought I had killed it - just took about 95 seconds or so and performance seems to be better (maybe it's my imagination!).
Keep us posted.
Time to create page: 0.154 seconds
We have 792 guests and no members online
