Cracked deck plate
  • Carl D
  • Carl D's Avatar Topic Author
1 year 10 months ago #7539 by Carl D
Cracked deck plate was created by Carl D
Some friends of mine are about to pull the trigger on an IP 420. Apparently, it has a cracked (broken) deck plate.  The owner claims it was replaced with a 2 piece deck plate.  That sounds sketchy to me for a number of reasons.  Has anyone heard of such a thing?  Also, what reasons other than sever trauma would cause the cast aluminum plate to crack in the first place?
My friends are in the UK so they aren't able to view it in person.  Below is a picture they received:
Thanks!
Carl
1 year 9 months ago #7541 by Aquavit362
Replied by Aquavit362 on topic Cracked deck plate
Check out Isomat deck plates at Rigrite. Isomat spars are common with island packets, may be true also for the 420 as it sure looks like it. There are no two part deck plates o have seen but it is possible that it has a specified mast wedge collar that fits with it. Cast aluminum is very brittle and can crack as cast iron. Seeing the crack is by the screw, it could of been overtighted or stessed if the plate was not uniformly flat bedded on the cabin top. It is replaceable but will require mast un-stepping.
1 year 7 months ago #7545 by MacMcDermid
Replied by MacMcDermid on topic Cracked deck plate
Adding to what Aquavit362 said. I have not seen a two-part deck plate here before. Yes, to install a new single-piece one requires pulling the mast.
Damage assessment could show as simple as Aquavit362 said. However, I would carefully inspect the mast partners where they enter the cabin top AND the keel mount plate to determine if another more serious trauma occurred and if that caused damage downstream.
Mac McDermid IP37 "Hamba Kahle"
Time to create page: 0.213 seconds
We have 1528 guests and no members online
