Rolling fuller fo IP27
  • seaweeble
  • seaweeble's Avatar Topic Author
1 year 7 months ago #7527 by seaweeble
Rolling fuller fo IP27 was created by seaweeble
Does anybody have suggestions for what brand and size of furler to put on our '86 IP27? I've never needed one on my Montgomery 17.
Seaweeble
1 year 7 months ago #7528 by zenGator
Replied by zenGator on topic Rolling fuller fo IP27
I assume you are thinking of this for the headsail. We installed a Harken Mark IV on our Morgan Out Island 28, a similar size to your IP27. It was a fairly simple two-man job. The unit is robust and works well. To the extent it matters, it is designed as a roller reefer. (I've seen some discussions that a roller furler is designed to be either all-in or all-out--not partway--and so isn't suitable for reefing. I don't know how true that is, but I do know that the headsail should be cut/designed for use on a roller reefer, with padding to create the proper shape when only partially deployed.  If you don't reef, I think it doesn't matter, but I'm not a sailmaker.)
One thing I like in particular about the Harken furler is that it has two slots, so that if desired I could run a second headsail up simultaneously and (a) fly it on the opposite tack for downwind sailing, or (b) keep it on the same tack and lower the other if I wanted to change headsails without losing speed. (Say, if I were in a race. Yeah, I know, funny: racing either an Out Island or an IP.)
The following user(s) said Thank You: seaweeble
  • seaweeble
1 year 7 months ago #7529 by seaweeble
Replied by seaweeble on topic Rolling fuller fo IP27
I've talked to couple of reefing systems and they keep asking me what pin size the boat has. What are they referring to?
Ian
Time to create page: 0.137 seconds
We have 1066 guests and one member online
