Steve, I have a 1995 IP40. At least on my boat the sump pump is located in the starboard lazarette mounted on the bulkhead between the galley and the lazarette. Next to it is a second pump for the fridge/freezer drain. Strainers for those lines (they can get clogged pretty fast due to debris that ends up in your bilge and sump) are located in the engine compartment (starboard side, bulkhead).
BTW, if your sump water source is not your mast, then it can also be your anchor locker. In a hard or steady rain, you will get water ingress from the anchor chain through-deck fittings, and the mast as well.
Hope this helps. Bobby
