Hi Bill, In 2019, we replaced the hot water heater on our IP380 with the same as original, except in White Aluminum instead of gal steel. - Seaward Marine Water Heater - 11 Gal- Rear Heat Exch 120V - White Epoxy, model S1100W. I ran out of time, so had the yard do the install. I think there were only 2 tabs, one in front, other in rear. It came out through the access in aft cabin. The yard also replaced the engine hot water hoses (20 yrs old) and added shut off valves near the engine, so easier to service later (if needed). I think the harder part may be replacing the hoses at the back of the hot water tank. We got our tank at Defender - but currently back ordered.
Looking for your tank, I found pix and specs here, but not sure if this is exactly yours,
www.boatandrvaccessories.com/products/at..._sid=22740f3fc&_ss=r. "This product has been discontinued by the Manufacturer and replaced by Attwood Seaward F1100" . You may just have to do web research and find a good replacement.
