Over the last 6 months or so I've started getting a good bit of "grit" coming through both the galley and head fresh water faucets. For the life of me, I can't imagine where it got in, in the first place, but it's definitely coming out.
I'm thinking of trying to flush the tank out by repeatedly filling it, and then suctioning it out rapidly - much like polishing a fuel tank. Access would be the top of the tank, through the opening where the tank-level sensor is.
I realize I can't snake a suction want around every place in the tank, because of the baffles, but I can't help but think getting as much grit out as possible would be a good thing.
At the end of the day, I may have to wind up installing a filter on the pick-up line, before the pressure pump, but that seems like a redundant solution to me.
Has anyone ever polished the water tank? Any suggestions or thoughts would be appreciated. Thanks in advance!
IP-32, #102 "Whimsy"
