Cockpit drain hoses IP380
  • LuckyJoe
  • LuckyJoe's Avatar Topic Author
5 years 5 months ago #6683 by LuckyJoe
Cockpit drain hoses IP380 was created by LuckyJoe
I am hoping someone can provide advice on changing the cockpit drain hoses on the IP380. They are finished on my new-to-me boat, and must be replaced immediately. I see that the IP35 solution is to go through the aft cabin. Any suggestions are welcome, my arms might not be long enough to get it from the port and starboard lockers.
5 years 4 months ago #6684 by Gitgo
Replied by Gitgo on topic Cockpit drain hoses IP380
I went thru the cockpit lockers to gain access to the cockpit drain hoses.
Using a Dremel tool with a cut off wheel (be careful not to cut the fitting) worked best. It takes time and perseverance.
  • LuckyJoe
5 years 4 months ago #6685 by LuckyJoe
Replied by LuckyJoe on topic Cockpit drain hoses IP380
Thank you very much. How were you able to reach the aft end (discharge) of the hoses? I did not think my arms were long enough. On the stbd side I can remove the linear drive for the auto helm, that should let me get somewhat closer.
5 years 4 months ago #6686 by Gitgo
It wasn't easy. I laid on my side and stretched to my limit. Another option is getting someone smaller to wiggle into position. Wear long sleeves so you don't get too banged up.
I didn't remove the autopilot arm.
When you place the new hose on, use a little dishwashing liquid to help slide the hose on. Don't forget to put the hose clamp on first on the hose so you can slide it in position. Maybe someone else has an easier solution.
The following user(s) said Thank You: LuckyJoe
Time to create page: 0.118 seconds
We have 890 guests and one member online
