Deck wash
  • margo
  • margo's Avatar Topic Author
15 years 9 months ago #364 by margo
Deck wash was created by margo
I can't figure out how to get the deck wash on my IP 38-168 to pump...
here's what I see.. there is a on/off switch for the windlass near the nav station.. next to the windlass breaker
the pump for the deck wash is located in the forward head, port side and is wired to the windlass button on the deck and the windlass motor..
as a result, I think the deck wash is designed to pump when the windlass is in use... but the motor doesn't turn and I can't get it to pump (obviously)
can you share how your deck wash is wired and works.. thanks
Margo
Margaret Dolan
s/v Windseeker IP 38-168
Port Kinsale, VA
15 years 9 months ago #365 by a Guest
Replied by a Guest on topic Re: Deck wash
Our washdown pump is wired to a breaker on the auxilary DC panel. When I turn the circuit breaker on the pump runs.
Use a volt meter and trace power to your pump - chances are you have a corroded connection or perhaps a bad pump.
Time to create page: 0.120 seconds
We have 914 guests and no members online
