IP 380 - Shaft Log Grounding Conductor
  • markle
  • markle's Avatar Topic Author
1 year 4 weeks ago #7520 by markle
Hello, I recently acquired 'Alcyone', a 2000 IP 380 and am currently undertaking a mini refit.I've observed that the grounding conductor, which, as per the IP 380 manual, terminates on (or near) the log shaft, is currently hanging loose
File Attachment:
. It appears someone previously attempted to address local corrosion with a questionable collar anode.
Could you please provide details or a picture showing the original factory termination point for the log shaft grounding cable, or suggest an alternative solution?
Thank you much
1 year 4 weeks ago #7521 by zenGator
Replied by zenGator on topic IP 380 - Shaft Log Grounding Conductor
Attached shows how the factory was doing it in 2020--just a simple hose clamp compressing the bare wire against the log.  Note the strain-relief zip-tie against the shaft log.
If I were redoing mine, I would (a) sand and polish the contact area and (b) goop silicone grease all over the bare wire before clamping it down.  In fact, I may do that preemptively.
  • markle
1 year 3 weeks ago #7522 by markle
Replied by markle on topic IP 380 - Shaft Log Grounding Conductor
Thank you ZenGator, this answers my question and will solve the issue!
  • markle
10 months 3 weeks ago #7525 by markle
As an update for those interested: Instead of clamping the bare wire of the bonding conductor (per factory) to the stern log, I opted to drill a hole in a clamp and use a # 10/24 copper screw with 8 AWG terminal.
Time to create page: 0.167 seconds
We have 1061 guests and one member online
