4JH3E 2004 370 ———- overheats under load only . Runs at 180 degrees unloaded
  • NorthB600
  • NorthB600's Avatar Topic Author
2 years 11 months ago #7462 by NorthB600
runs at 180 degrees unloaded at mooring . Underway temp rises until alarm goes off, running at 2800 rpms. Appears to be plenty of raw water discharge . Fresh water coolant topped off. Engine has 850 hours on it. Anyone else have same issue?
2 years 11 months ago #7464 by twofortheroads
Easy to be fooled by raw water discharge. When was the impeller last replaced and has the heat exchanger tubes been checked? For example, if an impeller blade where to break off it will land in the heat exchanger. Finally, is the prop and bottom clean. A fouled prop will definitely cause exactly what you described, I know from experience.
Time to create page: 0.209 seconds
We have 909 guests and no members online
