ENGINE BLOW BY ?
  • capjules
  • capjules's Avatar Topic Author
10 years 11 months ago #4131 by capjules
ENGINE BLOW BY ? was created by capjules
Hi,
I have a Yanmar 4JH4AE with 740 hours on it. I bought the boat with 520 hours on it.
Max rpm is 3000, I had been cruising at 2000 but I keep hearing faster is better so
I began cruising at 2600. After several hours at 2600 I can smell a little burning oil inside
the boat. I checked the engine and found a little oil on the outside of the air intake manifold, along
the bottom edge of the cover plate. I can also smell a little burning oil in the exhaust from time to time
but I can't see any smoke. There is no noticeable consumption on the dip stick.
Is this engine blow by ? Is this normal ?
Jules
10 years 11 months ago #4136 by hayden
Replied by hayden on topic ENGINE BLOW BY ?
Jules:
I have had this issue on my Yanmar 38 hp 3JH2e if I keep the oil at the full mark. Then if I keep the oil at the mid point it is less. I also too the air intake cover and inserted a sheet metal screw into the cover closing the small hole that the oil is coming out of. This is happening because of the crankcase breather hose that comes from the front of the engine and allows oil to come back into the air intake. This oil mist is to be re-burned. What I would find is that it would come out this tiny hole in the air cover, so I plugged the hole. I also run the oil level at mid point. This helps.
  • capjules
10 years 11 months ago #4137 by capjules
Replied by capjules on topic ENGINE BLOW BY ?
Thanks Hayden !
2 years 4 weeks ago #7519 by GB
Replied by GB on topic ENGINE BLOW BY ?
Hi Hayden, I’m replaying to this old post because i’m experiencing the same problem on my 1999 350.
I’m gomma to reduce the level of the oil from 3/4 to mid point but in the meanwhile i opened the air intake to be sure that air filter is clean and not clogged.
Inside the air intake I just found a not removable metal net (see picture)…Is this the filter or just the filter housing?
Thanks in advance for your help
Giuseppe
Time to create page: 0.191 seconds
We have 1234 guests and no members online
