Stern rail outboard mounting bracket
3 years 11 months ago #7312 by Lyons
We recently purchased an IP 420 that has an outboard bracket for the backrest to one of the perch seats. A friend of ours has and IP 320 and would like to purchase the same product. Does anyone know where this is available? I cannot find any  brand name markings on it. Please see the attached picture. Perhaps it was custom made. Thank you. -Bill Lyons
3 years 11 months ago #7319 by MELGYVER
Replied by MELGYVER on topic Stern rail outboard mounting bracket
That looks like a plastic bracket I just bought to replace my UV damaged flaking one, but covered with a SS Plate. I think it might have been “Five Oceans” Brand. Here is the amazon title: Five Oceans FO1586 Rail-Mount Outboard Motor Bracket, Up to 80 lb and 1 inch (25.4mm) Rail Diameter, UV-Stabilized Polypropylene, Stainless Steel Hardware Included… but I got mine at a local chandlery.
3 years 11 months ago #7322 by Lyons
Replied by Lyons on topic Stern rail outboard mounting bracket
Thank you Melgyver! Please let me know if that works. On the IP 420 and IP 320 the vertical portion of the rail is at a slight angle. This product looks like it might only accommodate a 90 degree angle. But maybe there is enough wiggle room in there for it to work.
3 years 11 months ago #7323 by MELGYVER
The one I got was: “Sea-Dog Rail-Mount Motor Bracket”.
I haven’t installed yet, but found my receipt! I’ll let you know if it works on the vertical.
The following user(s) said Thank You: Lyons
3 years 11 months ago #7324 by Lyons
Thanks again, Melgyver!
3 years 11 months ago #7325 by LJD610
Replied by LJD610 on topic Stern rail outboard mounting bracket
I ended up building a simple outboard mount with a strong piece of teak for our 420. I using 3 stainless U bolts for rail attachment. Held up fine with 15hp outboard over many sailing miles
3 years 11 months ago #7326 by Lyons
Thank you!!
3 years 9 months ago #7367 by MacMcDermid
Replied by MacMcDermid on topic Stern rail outboard mounting bracket
On my IP31, I built a teak mount with U-Bolts.
On my IP37 I purchased the one shown in the attached picture. I did have to use a Dremel to modify slightly to allow for the vertical offset as you have mentioned
3 years 9 months ago #7368 by MacMcDermid
Apologies, the picture does not show the brand. this one includes the brand and contact info.
3 years 9 months ago #7369 by MacMcDermid
Sorry, bad picture quality.
Better Bracket. www.simplesystemmarine.com (401)245-6949
Time to create page: 0.234 seconds
We have 791 guests and no members online
