AB 10 VL, fantastic dinghy
12 years 2 months ago #2929 by Rwirtz
Replied by Rwirtz on topic Re: AB 10 VL, fantastic dinghy
Thanks for you thoughts on the 10 vs 9 ft; we will go with the larger dinghy but doubt we can swing the $5,500 for the aluminum floor model Any idea as to how the AB 10 VL compares with the AB 10 ultralight? If we have to purchase an engine in the US, any suggestions as to hp and model?
We will also need to upgrade the anchor, and I'm leaning toward the Rocna 25 (55 lb) based largely on your recommendation in discussions on that topic. Is 5/16 inch chain sufficient for an IP380? Also, any suggestions at to what shackle swivel to use? As always, thanks for the sage advice. I'm sure you will be hearing from me a lot with questions, esp. the next few months.
Bob
12 years 2 months ago #2931 by hayden
Replied by hayden on topic Re: AB 10 VL, fantastic dinghy
Bob:
If you want the fiberglass model then the 10 VL is the way to go, you do not need the bow locker. It gets in the way.
www.abinflatables.com/ventus-10-vl
If you can afford it, then I would move up to the 10 AL model, it is the best.
www.abinflatables.com/lammina-10-al
This commonly includes the bow locker and ordering it without the bow locker is a special order.
AS for motors, if you will ever get to the Abacos, like in the next 2-5 years, then I would buy a cheap used 4 hp for now to use until then. At that point I would then buy the Yamaha 15 2 stroke in Abaco. Hands down the best motor on the planet. $2500 this summer (2014) at Abaco Yacht Services on Green Turtle Cay!
Your topic on anchors should have been a NEW post, that way it will not get lost under this topic on AB dinghies.
Yes, the ROCNA 55 lb anchor (25 kg) is fantastic and has worked very well now for two years for us. The 5/15 HT chain is perfect. It has a breaking strength of 4,000 lbs (3900 actually) It will hold your 380.
We have a great document of references about chain and shackles here: Study up :-)
ipyoa.com/forum/32-anchors-and-windlasse...ain-and-shackles-wll
Hayden....enjoying your discussions and questions.
12 years 2 months ago #2932 by hayden
Bob:
About the 15 HP Yahmaha. I just did a Google Search to buy a used one and found this:
www.smalloutboards.com/y1507.htm
Maybe you can find a used 15, two stroke. Do not give up on this idea. It is perfect with the AB 10.
  • rhpike
  • rhpike's Avatar
  • Moondance - IP440 #35
12 years 2 months ago #2933 by rhpike
Replied by rhpike on topic Re: AB 10 VL, fantastic dinghy
I already called them. This is an old ad and they have no 2-stroke 15's available.
Randy
S/V Moondance
IP440 #35
Houston, TX
12 years 1 month ago #3308 by Rwirtz
We just purchased a used AB ultralight (aluminum), 9.6 ft with a 5 hp Honda engine for use with "Southern Cross" the IP380-48 we purchased last week. We will see how this works, and get a 9.9 hp engine if needed. :)
12 years 1 month ago #3318 by Rwirtz
I was able to buy a used AB 9 ft ultralight, aluminum bottom as you suggested, with a 5 hp Honda engine and will see how it meets our needs. Combined weight of 135 lbs is nice. Majority of the time it will be just my wife and me.
Bob
12 years 1 month ago #3322 by hayden
Bob:
Buying the AB Aluminum was a great decision. I am sure you will love it. Plus it will last 10+ years!
11 years 9 months ago #3676 by JVoyt
Replied by JVoyt on topic Re: AB 10 VL, fantastic dinghy
Greetings Hayden,
We're planning to replace our 13 year old Avon 310 hypalon RIB this spring and are considering the
Zodiac 310 Hypalon RIB. This RIB weighs in at 191 lbs - a bit more than the AB 10 VL. By chance did you consider the Zodiac 310 during your purchase of the AB? You've got me thinking about the AB, and am interested in any thoughts you might have regarding the Zodiac vs the AB.
Best regards,
Joe Voyt
Free Spirit
IP420-55
11 years 9 months ago #3677 by hayden
Joe:
I did not look at the other dinghies. I am sold on the AB product line. I have the 10 footer VL light fiberglass, but again, if I could afford it I would get the 10 foot aluminum one.
It is 117 lbs.
It takes a 20 hp motor, but I would use the yamaha 15 hp two stroke.
11 years 8 months ago #3714 by rourkeh
Replied by rourkeh on topic Re: AB 10 VL, fantastic dinghy
Just purchased an AB 10 al with an Evinrude 25hp E Tec and it is a great performer.
Best dingy I have owned in this size range, 6 gallon fuel tank and PWC gel battery fit in the bow locker which keeps the deck clear. This boat and engine combo will plane and run 25mph with four full size people onboard, and is extremely dry.
5 years 3 months ago #7051 by 1Sailor
Replied by 1Sailor on topic AB 10 VL, fantastic dinghy
Hayden:
Just found this old thread while looking for information regarding a possible inflatable for the IP 38 we hope to purchase in the near future. We are thinking of going with a 9 ft AB aluminum bottom.
We do all our sailing in the North (Maine & Canada). I noticed that you have also sailed up in Maine. Did you have any problems going ashore with your inflatable? I am concerned about the possiblity of puncture issues since there are no nice sandy beaches.
Weight of the dinghy, and also the motor are very imporatant issues for us because my wife had a difficult time lifting heavy objects --- such as dinghies when the tide had gone out. Did you find that the 4 hp motor you had did the job? And I was wondering why you went with the 4 hp when at least now a days a 6 hp is the same weight?
Thanks for any insights you may have to offer.
5 years 1 month ago #7079 by wanderer
Replied by wanderer on topic AB 10 VL, fantastic dinghy
I have owned an AB 9' with the double fiberglass hull for over 15 years in the Florida sun and it is still going strong, though showing its age. This tells me AB makes a good product. My next one will be the aluminum hull. The aluminum is both lighter and more damage resistant than the fiberglass, so I believe it will fit your needs.
The following user(s) said Thank You: hayden, 1Sailor
Time to create page: 0.151 seconds
We have 1657 guests and no members online
