engine rpm
  • a Guest's Avatar Topic Author
14 years 5 months ago #1168 by a Guest
engine rpm was created by a Guest
I have a 31' IP, w/27 hp 3 cyl yanmar. what rpme should she idle and what rpm at full load?
14 years 5 months ago #1169 by hayden
Replied by hayden on topic Re: engine rpm
We had that engine in our 27. Idle should be 800 rpms and full out without a load is about 3600 with a full loaded prop about 3000. If the prop is over pitched like most are, then full loade rpms will be less.
14 years 2 weeks ago #1419 by raceboat61-S
Replied by raceboat61-S on topic Re: engine rpm
If your RPM's are low, the very first thing to check is barnacles or a fouled prop. This is fast and cheap. Just need a snorkle and a paint scraper. If that doesn't cure your problem pull the riser ("U-shaped) on the top of the exhaust manifold. They 'carbon-up' and block the flow of exhaust. Mike
Time to create page: 0.102 seconds
We have 1111 guests and no members online
