Winch Rebuilding
  • Vandergraaff
  • Vandergraaff's Avatar Topic Author
7 years 11 months ago #4855 by Vandergraaff
Winch Rebuilding was created by Vandergraaff
I need to rebuild the two halyard winches on the mast. Will this orientation create special difficulties, i.e. will parts start falling out as I begin disassembly?
Is it better to remove a vertically mounted winch an rebuild it on a more level service?
Art
7 years 11 months ago #4859 by hayden
Replied by hayden on topic Winch Rebuilding
Art:
I moved your original post to Yacht Systems, no problem.
As for working on the mast winch, I would work on it in place, BUT, I would cut a cardboard box and tape it around the mast under the winch as to catch any part that you may drop. When re-assembling the winch I would use winch grease that will hold all the paws in place. The winch grease is so sticky that it should do the job. That is the way I would do this.
Time to create page: 0.192 seconds
We have 526 guests and no members online
